Author Topic: Wire and soft rubber seal on soft top.  (Read 1800 times)
Mike H
  • Australia, New South Wales, East Ballina
« on: November 17, 2019, 06:57:11 »
I am installing the soft top frame.
I have the thin wires with eyelet on one end ,and the soft rubber wedge shaped seals.
I've read the softtop manual on this site, but found no answers to...
Where and how is the non eyelet end of the thin wire attached ...and
Where do the soft seals reside and oriented.  These parts were not present on removal.
My car is early 64 and I can't find find an anchor point for the end of the wire on my frame
Any photos would probably explain best, and would be most appreciated.
Mike. .
mbzse
Re: Wire and soft rubber seal on soft top.
« Reply #1 on: November 17, 2019, 08:50:38 »
Quote from: Mike H
.../...Where do the soft seals reside and oriented.../...
Some info here:
https://www.sl113.org/forums/index.php?topic=29962.msg217042#msg217042
/Hans S
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #2 on: November 17, 2019, 11:57:19 »
These photos might help you out.
« Last Edit: November 17, 2019, 12:09:04 by mrfatboy »
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Mike H
« Reply #3 on: November 18, 2019, 03:28:21 »
Photos were great,problems solved.
Thanks very much guys,
Mike.
