Please check out joining the Emergency Contact List for help during your travels!
Cory, you may want to check, but following some discussions on this Forum I came to conclusion that 280SL had black thumb nuts for their headlight assemby in the trunk (late style), e.g. https://www.sl113.org/forums/index.php?topic=28383.msg205095#msg205095You can buy them at Mercedes dealer, A 111 990 02 57, should be $5-6 dollars per piece, you need 4 for 280SL late style, they hold the bulb holders, not the entire lamps, unless you have other type of lamps where you need to remove the entire lamp to get to bulbs.
Pawel: was that a special option? "headlight assembly in the trunk" … Have not seen that and mine does not have them.
