Author Topic: headlights not working  (Read 4148 times)
rmmchl
  • USA, WV, Charleston
« on: November 26, 2019, 00:24:26 »
for some reason, both front beam headlights are not working, the lower box that contains park lights and blinker is working. the turn signals also work. the fuses look good, and can't see any that look bad. does one fuse control the front headlights? If so, does anyone know the fuse number. thanks
michael romeo
1967  250sl
signal red
dirkbalter
  • USA, CA, Corona
Re: headlights not working
« Reply #1 on: November 26, 2019, 01:12:04 »
Here is the fuse legend. It doesn't look like one fuse controls all the components you are missing
Dirk
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #2 on: November 26, 2019, 01:53:59 »
Try spinning the fuse for the headlights back and forth in place in the fuse box.  If this doesn't help we can go to another step
rmmchl
« Reply #3 on: November 26, 2019, 02:00:36 »
do you know what fuse is for the front headlights?
michael romeo
1967  250sl
signal red
« Reply #4 on: November 26, 2019, 02:06:10 »
9 + 10 are high beam and 11 + 12 are low beam.  Easiest way to check if fuse not working, is your turn signals working, they are on the same circuit as No.9
rmmchl
« Reply #5 on: November 26, 2019, 02:50:29 »
garry, the turn signals are working
michael romeo
1967  250sl
signal red
rmmchl
« Reply #6 on: November 26, 2019, 02:59:04 »
great news. they are working. I don't know why they were not. I had squirted the water hose into my grill to clean off some polishing paste. Maybe I got some connection  wet. Whatever it was, it fixed itself. I had some touchup paint work done, and had the rear tail lights removed. Maybe that had something to do with it. A mystery solved. Thanks Garry. Good to hear from you again
michael romeo
1967  250sl
signal red
