On another note discussing automobile paint care. Many owners never open the owners manual, this may be in fear that they may learn something or that a warning may appear , I say both. Education is the key factor in automobile care.
The days of the three stouges are no more. today unless you own a classic car from the days of the by goen eara and have single stage enamel paint or laquer on it. the products have changed even the famous Meguires #7 show car glaze is much drier and not as oily as it used to be.
The reason for this is what is called low solvent high density paints have become the new source of the automobile manufactures. Old type high solvent paints that keep on gasing off are no longer used. these paints had so much solvent in them they needed emense glazes to feed the binder to keep it from drying out.
Todays paint systems the best in the industry are base coat /clear coat technology. What you are polishing is the clear unpigmented coat of clear paint designed to protect the basecoat from the UV exposure of the sun and elements out side your control.
Different products are needed to protect , polish and maintain this new paint system.
Never Ever!!!!! reach for the most agressive compound to remove a mark on your Mercedes-Benz paint always use the lease aggressive paint cleaner or mild polish first. To remove industrial and enviromental fallout from the surface of the paint hood, roof trunk and rear sholders of the quarter panels use detailers clay after hand washing the automobile. Clay is vantastic if used correctly and will remove with out scratching the surface of the paint fall out that compound would only force further into the paint while removing fresh clearcoat.
Here are some basic things to have at hand.beside clay to be purchased for the Mercedes-Benz owner. "
1) a mild clear coat paint clearner mild not agressive like a compound it will break down in deminishing partical that become like a fine polish .
2) a pure paint polish no cleaners some are called glazes they are fillers that give the paint a wet look.
3) a pure carnauba paste wax oil base or water base .
4) a good supply of micro fiber towels for use on paint, glass chrome and interior.
5) a good mild chrome polish
6) a good synthic chamie firemans friend will notstripe the wax of the car.
7) I forgot a good automobile Carwash solution for automoble paint leave your wife's dishwashing soap alone and were it belongs.
of corse it should be number ONE Clay magic blue bar and clay lubricant .
If you have a paint questions and seek further help and guidence you can bend my ear not my Mercedes! at bobgeco@cs.com
Happy motoring
