Become a
Full Member
Emergency Contact List
Barometric compensator (BC) removal quick questions
Topic: Barometric compensator (BC) removal quick questions (Read 2469 times)
Greg R.
Associate Member
Junior Level
USA, DC, WASHINGTON
December 02, 2019, 13:37:37 »
Good morning.
1) What size wrench fits the hex section? (17mm?)
2) Must a thin tappet-style wrench be used or is there another technique? My search here last night didn't turn up anything.
-Greg
1967 230SL w/ 250 motor
Greg R.
Washington, DC
W113 1967 230SL (auto, 250SL motor)
E24 M635
E38 740i sport
S3 Spider Veloce
ex-E32 735i, ex-E24 635CSi turbo, ex-1965 Falcon Futura convertible (301W H.O. transplant)
Re: Barometric compensator (BC) removal quick questions
December 02, 2019, 14:33:16 »
The baro requires a 19 mm wrench. I think youre on the right track for its removal. Been a long time since I replaced my baro
Vendor
Platinum
USA, TX, Dallas
Reply #2 on:
December 02, 2019, 16:09:02 »
Be on the look out for thin shims under the BC when you take it out. Not sure why you are taking it out, but some use this to do a quickie full range fuel mixture adjustment. You can also test the compensator to make sure it hasn't failed while it is out.
https://www.sl113.org/forums/index.php?topic=12175.msg82217#msg82217
Jeff knows quite a bit about these pumps.
Inactive
Platinum
USA, OH, Cleveland Heights
Reply #3 on:
December 02, 2019, 16:12:12 »
I walked out to the garage and slipped the fattest 19mm I had (.35 inches thick) onto the baro of my 1970 and it worked fine.
Greg R.
Associate Member
Junior Level
USA, DC, WASHINGTON
Reply #4 on:
December 02, 2019, 16:15:54 »
Thanks everyone.
I'll try a couple of 19mm's I have and see what'll squeeze in there. Thanks for the reminder about the shims.
Yes, I suspect that it has failed or at least want to eliminate it as a variable in my starting & running issues.
Greg R.
Washington, DC
E24 M635
E38 740i sport
S3 Spider Veloce
Full Member
Platinum
USA, OH, Blacklick
Reply #5 on:
December 02, 2019, 17:05:43 »
When the baro fails, the system usually goes lean.
Greg R.
Associate Member
Junior Level
USA, DC, WASHINGTON
Reply #6 on:
December 07, 2019, 22:26:05 »
Thanks again, all.
I removed the BC and confirmed that it is kaput.
-Greg
Greg R.
Washington, DC
E24 M635
E38 740i sport
S3 Spider Veloce
