Author Topic: Fuel Injection Pump Dip Stick  (Read 2193 times)
Klaus Pieper
  • South Africa, KwaZulu-Natal, Westville
« on: December 03, 2019, 13:00:34 »
Hallo,
I have a 1966 230 SL with fuel injection pump PES 6 KL 70/120 R11 which is the correct fuel injection pump for this model.  I can however not find the dip stick on this fip.
Although I have used the search function and the technical manual, I can not find a photo showing the position of the dip stick nor an accurate description where to find it.
Any help would be greatly appreciated.
Klaus
cfm65@me.com
  • Cape Town, South Africa
Re: Fuel Injection Pump Dip Stick
« Reply #1 on: December 03, 2019, 14:24:53 »
Hi Klaus,
The old type injection pumps have a closed system as you said( it does not use oil from the engine) The dipstick is at the back of the pump, closest to the firewall. It has a tiny T handle which screws out. Follow my arrow.
Regards
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #2 on: December 03, 2019, 16:33:15 »
Another picture…………………….
Paul & Dolly
  • i Car
« Reply #3 on: December 03, 2019, 20:16:01 »
Hi Klaus
This a post you need should find useful
https://www.sl113.org/forums/index.php?topic=26563.msg190027#msg190027
230SL Injection Pump Oil of 6 September 2017
Have a look at the guidelines for using the search function.
Keep well
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
Klaus Pieper
« Reply #4 on: December 04, 2019, 08:54:55 »
Chris, Joe and Paul, thank you so much for the quick response - it has been very helpful and I will now check the oil level as suggested with the cable tie.
Klaus
