Author Topic: 230SL Auto transmission - locked after re-installing it?  (Read 1801 times)
Nikolaj
  • Denmark, Kobenhavn, Copenhagen
« on: December 07, 2019, 20:44:00 »
I have just re-installed the engine and auto tranmission after a major engine bay job. Still a lot of work to be done before I can start the engine but I needed to move the car around in my garage.
For some reason I can only move/push the car forward. Not backwards/reverse. It's completely locked.
I tried to change gear but no difference.
Any ideas?
Nikolaj
Re: 230SL Auto transmission - locked after re-installing it?
« Reply #1 on: December 07, 2019, 23:26:44 »
I hope you got the torque converter correctly engaged to the front pump?
« Reply #2 on: December 08, 2019, 09:25:57 »
Gear selector adjustment?
Nikolaj
« Reply #3 on: December 14, 2019, 18:14:47 »
I disconnected the gear selector arm and set it in N - problem sorted. Then did the adjustment and now all seems to be good.
Thanks for your help.
Regards
Nikolaj
