Author Topic: Early shifting auto.  (Read 3090 times)
« on: December 09, 2019, 05:47:54 »
My problem is the transmission shifts up and down properly and the kick down works. It seems to shift up too early and into high gear at about 90 kph regardless of how much throttle I use except for kick down. Throttle is going wide open so that's not it. I haven't looked at vacuum yet.  My info is that the trans was rebuilt.
Anyone run into this problem and what did you do to fix it?
Re: Early shifting auto.
« Reply #1 on: December 10, 2019, 00:14:12 »
My Bronco started having this problem last week after we re-attached the vacuum line from the intake manifold to the transmission pressure modulator that had popped loose. As a result of which it was not upshifting at all anymore. Reattached it and now it upshifts too soon. I need to check on this, but am pretty sure these issues are usually vacuum pressure related. The pressure modulator on the MB trans is adjustable as far as I know so it should be a relatively easy fix if that is the issue. Of course I am just an amateur so am grateful for others to weigh in.
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
« Reply #2 on: December 10, 2019, 04:49:27 »
I would also think it is a transmission pressure issue. If the engine vacuum to the modulator is present and correct then it could be that the transmission pressure is probably low. It can be measured and set correctly as described in the technical manual under automatic transmission, or easier still is to try an increase the pressure on modulator by turning the adjusting screw 1-1.5 turns clockwise. Make a mark of the original setting so that you could always revert to it in case it doesn’t have the anticipated result.
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
« Reply #3 on: December 10, 2019, 05:50:22 »
Yes, I am in agreement with " naristodemou" , try a bit more modulator pressure.
« Reply #4 on: December 10, 2019, 15:56:44 »
Will do and report back with results.
FresnoBob
  • USA, CA, Fresno
« Reply #5 on: December 10, 2019, 23:46:43 »
Hi Benz Dr.
I built a transmission modulator pressure gauge setup that I'm happy to loan you.  I'll ship it to you if you'd like.
Bob Comstock
1966 230 SL Euro Auto
2017 AMG C43 Cabriolet
« Reply #6 on: December 11, 2019, 06:37:08 »
Thanks Bob. I'll let you know if we need it.
