Author Topic: Frigiking AC Vents  (Read 5626 times)
TEJOLX47
  • Portugal, Lisboa, Lisboa
Frigiking AC Vents
« on: December 16, 2019, 16:20:18 »
Hello Pagoda friends,
A while ago I had to disassemble my Frigiking A/C cassette to clean it and I decided to re-chrome the air vents.
In order to do so, I had to remove the pins that move the vents from left to right and one of them got broke. So I had to fix it!
Once I couldn't buy them new, nor glue them, I decided to 3D print them. Which I did.
Please let me know if you want a copy of the 3D file for such pins (DWG format).
In the end I printed 3 pins and they work properly and look perfect!
Some pictures attached:
a. The vent (before re-chrome);
b. One of the pins removed without problem;
c. Draft print of the pin and the the fin that directs the air flow linked together;
d. pdf of the pin.
Please note that I also have a draft version of the fin but I never reprinted once it was not good enough.
Kind regards
Francisco
Francisco
1970 280 SL (US delivered, Auto, AC, PS)
181 Light beige with 423 Tobbaco brown top
teahead
  • USA, WA, Des Moines
  • aka "Rob"
Re: Frigiking AC Vents
« Reply #1 on: December 16, 2019, 20:38:06 »
Yes, I'll take a file.
Thanks so much!
ragtopdodge@gmail.com
GM
  • USA, CA, San Pedro
« Reply #2 on: December 16, 2019, 22:30:36 »
I'd like the file, please.
Thank you!
gary@garymyer.com
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
Delvis
  • Canada, British Columbia, Delta
« Reply #3 on: December 19, 2019, 04:32:53 »
if still available ... I too would like a copy of the 3d file. thank you in advance and Merry Christmas and happy 2020!
regards
devlin
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
teahead
  • aka "Rob"
« Reply #4 on: December 19, 2019, 05:02:03 »
Duh, he already attached the PDF to his post.
Danke!
 ;D
specracer
  • USA, MA, Duxbury
« Reply #5 on: December 19, 2019, 12:39:10 »
Hope someone adds this to the the "members" side of the tech manual. Great thinking to go that route.
« Reply #6 on: December 19, 2019, 21:11:05 »
The Tech Manual is open to all Full Members to use and to also add or amend to its content.
You can play in the sand box area first to feel comfortable to go live with amendments or additions.  We as a whole Group rely on everyong putting in some effort whether it be doing some Admin or adding to the knowledge of the Technical Manual so please feel free to add it to the Manual.
Membership Administrator
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
450sl
« Reply #7 on: December 20, 2019, 09:21:56 »
Hi Francisco,
I am struggling finding a place ,getting my frigiking vents rechromed.
Are you satisfied with the results of your rechrome ? / May i ask about the costs?
Mark
TEJOLX47
« Reply #8 on: December 20, 2019, 16:10:50 »
Hi Mark,
Chrome over plastic is not very common.
I searched a lot and eventually found a small company that does it.
Was it perfect? No. Just 7/10.
I guess they neglected the removal of the previous coat of chrome... but not sure.
However, much better than before.
I think I have paid 100€ for the 3 vents and shipping.
Kind regards
Francisco
Francisco
chumps
  • USA, CA, Santa Rosa Valley
« Reply #9 on: December 21, 2019, 02:45:32 »
I was able to disassemble my vents without doing any unrepairable damage. I sent them to www.chrometechusa.com. I can't remember how long it took them to do the chroming (I believe it was a couple of months) but they did a great job. When I reassembled them they looked great! It's been at least a couple of years, so I'm not sure if this company is still around. Good luck, Chumps
Delvis
« Reply #10 on: December 21, 2019, 07:37:17 »
Clarification. Reference/Request was for the .dwg file.
Merry Christmas all!!
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
450sl
« Reply #11 on: December 21, 2019, 11:25:02 »
Thanks Francisco, for the info.
Also would like the dwg for 3d printing of the knob.
Merry Christmas all
Mark
Josephkhoury
  • USA, DC, Washington
« Reply #12 on: June 12, 2023, 02:31:27 »
Can you please send me the file for the air vent tabs?
I have the same issue.
Thanks!
TEJOLX47
« Reply #13 on: June 12, 2023, 10:41:40 »
Hi Joseph,
Please send me your email so I can forward the files.
Cheers.
Francisco
Francisco
LA280SL
  • USA, CA, PACIFIC PALISADES
« Reply #14 on: October 25, 2023, 03:51:58 »
Francisco,
I am impressed with your ability to reproduce the pin in photo b.
I have disassembled the vent vertical vanes from the housing, but cannot figure out how to separate that pin/control knob from the vertical vane it is attached to.
I keep trying to spread the two “arms” from the vane but without success.   How did you get that done?
Thank you!
LA280SL
« Reply #15 on: October 25, 2023, 03:59:57 »
In case others have had success, here is the current vent status.
johnk
  • USA, OH, Avon
« Reply #16 on: October 25, 2023, 07:07:19 »
Take a hobby knife and slice the fingers off the side of the piece and then take a pliers and twist the knob off.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
TEJOLX47
« Reply #17 on: October 25, 2023, 08:33:18 »
I guess in some cases you will find out that the pin is glued to the fin.
In such cases, you will have do "brake the bond".
Try vinegar.
Try heat.
All things moderately.
I have to confess I have broken one pin when removing it, hence the need to reproduce it.
Good luck
F
Francisco
TEJOLX47
« Reply #18 on: October 25, 2023, 08:34:15 »
Looks great!
Francisco
LA280SL
« Reply #19 on: October 26, 2023, 05:05:04 »
Thanks Francisco
I worked the bond as you said with a small sharp knife to separate the edges and lifted the pin out. Whew.
Part of the journey of restoring these gems is how a seemingly simple process often becomes a full on challenge.
