Author Topic: Front subframe covers  (Read 2599 times)
getsmart
  • Australia, Victoria, Dromana
« on: December 17, 2019, 11:45:53 »
Hi all,
Does anyone know if the steel subframe mount covers had rubber on them on the underside?
I'm restoring mine and one had rubber and the other didn't though I wonder if someone had glued the rubber on
See attached photo,
Rgds, Joe
Finding the red car
1964 230sl Restoration Project
dirkbalter
  • USA, CA, Corona
Re: Front subframe covers
« Reply #1 on: December 17, 2019, 15:21:00 »
I have mine apart too. I don't have rubber on the inside of the plates.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
JohnnyC
  • USA, CA, Escondido, CA
« Reply #2 on: December 17, 2019, 16:39:23 »
Hi, I have ‘70 280SL and both left and right plates have rubber.
Cheers, JohnnyC.
John
'70 280SL (In Rebuild), Dk Olive/Cognac
'85 BMW Euro M635csi, Polaris Silver
'54 MG TF, Black
'01 Lazy Daze RV, White/Tan
'10 Genesis Coupe, Silver
'19 F150, Black
dirkbalter
  • USA, CA, Corona
« Reply #3 on: December 17, 2019, 17:23:12 »
Interesting, I don’t see the rubber in the parts catalogs either. I will check mine again for traces of rubber.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
mbzse
« Reply #4 on: December 17, 2019, 18:39:41 »
Quote from: getsmart
.../...Does anyone know if the steel subframe mount covers had rubber on them on the underside?.../...
Yes, there was rubber vulcanized onto there, on this part. See picture showing new part (From SLS website).
Purpose of the rubber disk was, that there would be some last ditch cushioning of the front suspension, when the subframe mount itself had separated/collapsed.
/Hans S
dirkbalter
  • USA, CA, Corona
« Reply #5 on: December 17, 2019, 21:09:00 »
As mentioned, mine do not look like they had rubber on them at any time. However, it is possible that they were changed at one point in the past.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
getsmart
« Reply #6 on: December 18, 2019, 03:08:02 »
Thanks everyone for the prompt replies. Now to work out how to glue some rubber back on in the event of subframe mount collapse which I guess will be unlikely as I'll forever keep an eye this baby once I get it running again.
The Germans thought of everything!!!
Cheers, Joe
The Red Car
Finding the red car
« Reply #7 on: December 18, 2019, 21:27:14 »
The plates are SL only and just keep the engine from rising enough to hit the hood.  The rubber just lessens the "smack" if you hit a really big bump.  I am not sure if it is the same as it used to be but the mount kit for a sedan which is the same lounts without the plates was much cheaper than the SL kit.
getsmart
« Reply #8 on: January 26, 2020, 06:40:40 »
Hi all,
Ended up restoring mine, here's a pic attached
Finding the red car
MikeSimon
  • USA, OH, North Royalton
« Reply #9 on: January 26, 2020, 15:23:13 »
Cheers, JohnnyC.
I thought the 280SL did not have these covers?
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #10 on: January 26, 2020, 15:47:47 »
I think what 280SL did not have were the plastic covers on top. I think I will use them, by the way, as quite some dirt is accumulating there...
MikeSimon
« Reply #11 on: January 27, 2020, 18:07:49 »
Sorry. Yes, Pawel, you are correct. That's what I was thinking of.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
