Author Topic: 230SL clamp reference  (Read 3262 times)
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
« on: December 21, 2019, 15:26:53 »
My '65 230SL presently has a combination of the old style strap and Norma clamps which may or may not be correct where they are applied.  e.g.the air cleaner has a strap clamp which I believe should be Norma.  Every engine bay picture I have seen has a different mix/application of clamps.
While I have read the clamp description in the Tech Manual, can anyone refer me to or possibly have an engine bay picture of a complete and correct use of the combined clamp types that they can point me to?  JB
JB; 1965 German market SL, Rot Met 571, Summary Code 213 Interior
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: 230SL clamp reference
« Reply #1 on: December 21, 2019, 16:03:45 »
Here are pics of 49er's original engine bay photos of his 250 SL and 280 SL that I use for reference for my car.
As I understand it all the Norma style clamps should have Phillips head screws in them except for the very early 230 SL's which have slotted.  However I have not 100% confirmed this. I look forward to a discussion on this😀
You can see in the photos there are at least 4 different clamps used around the engine bay.
Heater hoses & Brake booster hose
Power steering hose
Radiator hose
Everything else
« Last Edit: December 21, 2019, 16:28:16 by mrfatboy »
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #2 on: December 27, 2019, 17:22:04 »
The power steering return hose uses 2 special quick release screw clamps not used anywhere else.
« Reply #3 on: December 27, 2019, 19:27:14 »
They are not similar to those used on the coolant hose?
mbzse
« Reply #4 on: December 27, 2019, 20:13:41 »
Quote from: Shvegel
Quote from: Pawel66
The quick release type looks like this
« Last Edit: December 28, 2019, 16:44:20 by mbzse »
/Hans S
« Reply #5 on: December 27, 2019, 20:52:11 »
ok, this is the same one, I think, that is on the coolant hose, isn't it? Just different diameter. Or I am missing something?
mbzse
« Reply #6 on: December 27, 2019, 21:06:29 »
Coolant hose clamp, Beru 9mm width strap.
This type also used on the rear axle for the large rubber bellows.
« Last Edit: December 28, 2019, 16:50:52 by mbzse »
/Hans S
mbzse
« Reply #7 on: December 27, 2019, 21:22:33 »
Quote from: mrfatboy
.../...You can see in the photos there are at least 4 different clamps used around the engine bay.../...
Yes..  please note however, the clamp types installed from factory changed significantly sometime in 1969 (280 SL).
The earlier, band type tightened with a twist pin were replaced by C-clamp type with M4 tightening screw. See attached
/Hans S
« Reply #8 on: December 28, 2019, 09:52:32 »
I see, thank you!
« Reply #9 on: December 28, 2019, 15:54:04 »
Some cars originally used that  power steering supply hose clamp below the thermostat housing (in a larger diameter).
« Last Edit: December 28, 2019, 20:27:13 by ja17 »
