Author Topic: Engine Mount Limit Stops  (Read 1608 times)
PeterPortugal
  • Portugal, Faro, Lagoa
« on: December 23, 2019, 13:37:11 »
Hi All,
As per some other posts all my "limit stop" hardware was missing from the engine mounts which I removed from my car.
The problem I have is that my usual resources for new parts seem to be limited to the later style version with a hex head bolt fitted to secure the limit stop (127-220-00-71).
My 1963 220SE/C should have an M12 x 50mm threaded stud with two nuts, one to get the correct compression on the rubber washer plus a locknut.
Can I use the later style hex head bolt as used on W113?
Regards
1963 220se Cabrio
1968 280se Coupe
PeterPortugal
Re: Engine Mount Limit Stops
« Reply #1 on: December 31, 2019, 11:28:15 »
Hi all,
Thought I would give this one a push.
As per the image below my car should have the hardware on the left (same as early 230SL) but it is all missing.
Can I fit the later version hardware shown on the right which is readily available?
Regards
1963 220se Cabrio
1968 280se Coupe
« Reply #2 on: December 31, 2019, 14:52:33 »
Yes, changes over with no problems.
PeterPortugal
« Reply #3 on: December 31, 2019, 16:23:08 »
Hi Joe,
Thanks for replying and may I take this opportunity to wish all forum members a very happy New Year !
Regards
1963 220se Cabrio
1968 280se Coupe
cfm65@me.com
  • Cape Town, South Africa
« Reply #4 on: December 31, 2019, 21:37:26 »
Thanks Peter,
Happy, happy to you and your loved ones as well.
Regards
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
