Author Topic: Tire size for Fuchs 6Jx14H2 alloys rims  (Read 3663 times)
Berggreen
  • Denmark, Zealand, Gentofte
« on: December 25, 2019, 18:56:38 »
Dear All
I have been so lucky to find a set of five (5) renovated and original Fuchs 6Jx14H2 alloys rims for my '70 280SL (man). See pictures attached.
I know the 185R14 is the original tire size and most prefer this for the standard steel rims with hub caps, but what about the Fuchs 6" alloy rims?
I have been searching through both the technical manual and the forum for some clear recommendations for which tire size to use with these Fuchs alloys, but without luck. However, I have found statements that both 185R14, 195/75 R14 and 205/70 R14 have been used, but I don't see that there is a prefered size from what I can find.
SO, what do you recommend to fit on my new Fuchs alloys?  8)
Best wishes and Merry Christmas,
Christian  :)
02/1971 MB 280SL (aut.) - olive green 291H
11/1970 MB 280SL (man.) - silver 180G
12/1977 MB 350SE (aut.) - deep green 825H
03/1969 Volvo 1800S (man.) - dark green 94
MikeSimon
  • USA, OH, North Royalton
Re: Tire size for Fuchs 6Jx14H2 alloys rims
« Reply #1 on: December 25, 2019, 22:31:35 »
 A lot depends on your personal preference and what is available for a good price. When I replaced my 185R14s for my 6x14 Fuchs alloys, I bought 195/70x14, which may be one of the worst alternatives.
The 185R14 has an aspect ratio of .90, which makes the shoulder height 166.50mm. Of all the sizes you listed, the 195/75 with a shoulder height of 146.25mm will end up the closest to 185R14.
In order to get the same size total height for the wheel as a 184R14, you would need something like a 205/80.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Jack Jones
  • Canada, ON, Milton
« Reply #2 on: December 26, 2019, 03:40:27 »
The 185HR14 tire has an aspect ratio of 80 giving it an overall height of 25.65 inches (676.9mm). A 205/70/14 would provide you 25.4 inch height and the closet match to the stock 185HR14 tire. I am not aware of the existence of a 90 aspect ratio tire for a car.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
MikeSimon
« Reply #3 on: December 26, 2019, 15:00:04 »
I am sorry, I always thought the standard tire aspect ratio was "90". I seem to remember there were "80" designated tires out there. My bad!
In that case, a 195/75 with a shoulder height of 146.25mm would be the closest to the stock 185R14
You can still find 185R14s, in a Phoenix radial. In any case, I would try to find a tire with a "Scheuerkante" ( a raised ridge on the sidewall) to better protect your alloys.
« Last Edit: December 26, 2019, 15:19:10 by MikeSimon »
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
scoot
  • USA, CA, Altadena
« Reply #4 on: December 26, 2019, 16:16:53 »
Nothing changes with the tire size because you bought alloy rims.
Scott Allen
'67 250 SL (early)
Altadena, California
MikeSimon
« Reply #5 on: December 26, 2019, 21:20:04 »
I agree with Scott. Both steel and alloy rims are 6" and they would use the same tire. If you are for originality, the 185R14 is the way to go.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
Berggreen
« Reply #6 on: December 26, 2019, 21:44:26 »
Thanks guys!
Currently there is also discussions on the topic of tire sizes for Fuchs rims on several of the Facebook Pagoda groups, and it seems there are preferences for all of the three tire sizes I listed above. Some goes only original with the 185R14's and others want a beefyer look with the 205/70-R14's and other goes in between with the 195/75-R14's.
So I see it is very much up to personal taste and religion. ;-)
Cheers and Merry Christmas,
Christian
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #7 on: December 27, 2019, 13:59:34 »
The advantage of the 205/70 is braking distance and cornering.  The extra 20mm of rubber on each corner can make the difference between a near miss and a bad day.
« Reply #8 on: December 27, 2019, 14:21:01 »
the disadvantage is increased fuel consumption.
MikeSimon
« Reply #9 on: December 27, 2019, 15:01:45 »
...and a minor deviation in the indicated speed on your speedometer...
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
Berggreen
« Reply #10 on: December 27, 2019, 16:06:57 »
Hi Raymond
Do you possibly have a picture of your Pagoda to share with the 205/70's mounted on your car?
Christian
Jack Jones
« Reply #11 on: December 29, 2019, 02:04:04 »
The original size tire with the correct HR speed rating will provide superior handling compared to an SR rated replacement. Vredestein offers a 185HR14 with the tread pattern that suits what originally came with the Pagoda and most 205/70/14's available today will be a SR rated tire. I personally like the original size on our cars unless you are looking for a more aggressive stance.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
lowpad
  • USA, CT, New Preston
« Reply #12 on: January 02, 2020, 04:13:09 »
Here is a pic of my 230SL with 205 Vredesteins.  I like the look, but also have a set of more original MXV-Ps on steel wheels.  I find that the Vredesteins have great ride and handling and since my speedo is in km, the speed difference really doesn’t matter!
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
Berggreen
« Reply #13 on: January 02, 2020, 20:34:55 »
Thanx, looks GREAT! :-)
teahead
  • USA, WA, Des Moines
  • aka "Rob"
« Reply #14 on: January 03, 2020, 03:56:14 »
These are T-rated:
https://www.summitracing.com/parts/gti-15494960000/
Height differences from stock is negligible.
I just picked up some 6" aluminum 502 "steelies" so am in the market as well
