Author Topic: Crankshaft Bolt  (Read 2491 times)
Harry
  • USA, TN, Knoxville
Crankshaft Bolt
« on: December 30, 2019, 20:02:52 »
As part of my engine reassembly, I will need to install the CS pulley and dampener.  I have the "stretch" bolt with the waist area and it looks remarkably good.  I checked with my local MB dealer and they show it as available but nowhere in stock (US or Germany).
I wonder what the length of a new bolt is?  I could measure this one and see whether or not it has stretched/yielded in service.  Are there other tale-tales that I should look for?
Thoughts?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Harry
Re: Crankshaft Bolt
« Reply #1 on: December 31, 2019, 01:45:06 »
Here is a photo of the bolt in question.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Crankshaft Bolt
« Reply #2 on: December 31, 2019, 06:23:01 »
Never heard of one of these hefty bolts failing. If you like I can a used one for you.
Harry
Re: Crankshaft Bolt
« Reply #3 on: December 31, 2019, 12:11:59 »
Thanks Joe.  If it is common practice to reinstall the bolt that was there, I'm happy to do so.  This bolt looks very good - no distortions or visible damage.  Does the BBB indicate how it is to be tightened?  I will look but I'm sure that you know as well.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Crankshaft Bolt
« Reply #4 on: January 01, 2020, 07:20:03 »
No special procedure, just make sure to index the pins correctly in the front balancer, they are slightly off-set and must not be installed 180 degrees off
. Some minimal information in the late BBB 03-1/1, 03-1/2. Torque is 21 + 1 mkp (160 ft/lbs). Brace the flywheel to keep the crankshaft from turning when applying the high torque.
