Author Topic: Direction of fuel pump rotation  (Read 1371 times)
thomasw
« on: January 02, 2020, 19:56:21 »
Hi!
I'm currently assembling my later short style of fuel pump with the help of the excellent article on the Technical Manual section. It mention that you should test the direction before you proceed, if it is wrong you should turn the motor can 180 degree. But i can't see what the correct direction of rotation is? Anybody that knows that?
Correction: Found the arrow on the cover!
Greetings from Sweden.
Thomas
« Last Edit: January 02, 2020, 20:21:56 by thomasw »
Re: Direction of fuel pump rotation
« Reply #1 on: January 02, 2020, 22:46:13 »
Welcome Thomas, yes just switch motor connections 180 degrees to change DC motor rotation.
