Author Topic: Exhaust heat shield  (Read 3661 times)
Vander
  • USA, OH, Columbus
Exhaust heat shield
« on: January 05, 2020, 14:35:29 »
I am looking for a 280SL heat shield that goes between the exhaust manifolds and intake, clamps too. Does anyone have one?
cfm65@me.com
  • Cape Town, South Africa
Re: Exhaust heat shield
« Reply #1 on: January 05, 2020, 16:08:00 »
Hi Vander,
They are quite tricky to get out between the manifolds and after 50 odd years they normally look crappy.
The usuals have them for around 100€ and with a bit of patience, are possible to fit one without damage.
Good luck,
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #2 on: January 05, 2020, 17:27:00 »
I bought one a couple of years ago from MB. What I see today:
A 130 141 00 21 Screening (heat insulating plate) NLA, but then
A 000 141 10 21 Screening, ca$120 - but I have no idea how this one looks like - if it is not some sort of replacement, just not sure
You will need clamps as well. And for clamps I see:
A 000 995 16 35 clamp, ca $6
« Reply #3 on: January 05, 2020, 17:42:31 »
And for you really crazy people out there, don't forget to re-use the small circlip on the threads of the clamp for the heat shield. I believe these were used at the factory to hold the screw for the clamps in place during assembly.
When judging I have used this as a tie-breaker.
« Reply #5 on: January 05, 2020, 18:42:24 »
Absolutely critical!
Judging is one thing, the other is - you will crtainly lose the screw without it. I bought those clamps from MB and they had the circlips.
« Last Edit: January 05, 2020, 18:57:56 by Pawel66 »
« Reply #6 on: January 05, 2020, 18:46:29 »
The clamp from SLS does not look, I think, as it might have, I am afraid. The original clamp is profiled to fit the manifold shape. Tightening mechanism may also be a bit different, I am not sure.
On the picture you can see the clamp from MB, the circlip is, obviously, there.  :)
Also: these plates were two metal sheets with fibre between them (glass fibre, azbestos?). It is not a plane metal sheet cut and formed.
« Last Edit: January 05, 2020, 19:00:50 by Pawel66 »
Baybear
  • USA, VA, Midlothian
« Reply #7 on: January 07, 2020, 20:30:18 »
AuthenticClassics has the correct shield and clamps. https://www.authenticclassics.com/SearchResults.asp?Search=exhaust+shield
Will
Will Milby
1970 300SEL 6.3, 1971 280SL, 1972 300SEL 4.5, 1972 Super Beetle, 1998 SL500, 2010 350 GLK, 2012 SLS AMG
