Author Topic: 230SL IP parts  (Read 3033 times)
230SL IP parts
« on: January 10, 2020, 05:47:02 »
I'm looking for the warm running device that sits on top of a 230SL injection pump. I need the base, slide valve, and metal tube with two pipes for coolant hoses. I can get the thermostat but I will take a used one that works. Heat it up and as long as the pin move .050'' it's OK.
I need enough parts to do two different pumps but I could make one work with just the internal slide valve and the metal tube on top for one pump. The other pump needs everything.
Re: 230SL IP parts
« Reply #1 on: January 10, 2020, 08:01:54 »
Re: 230SL IP parts
« Reply #2 on: January 10, 2020, 17:35:17 »
that only covers the tube with pipes that holds the thermostat. It's a start though.
I would still need a slide valve.
