Author Topic: Becker Europa TR service notes  (Read 2263 times)
col320ce
« on: January 12, 2020, 21:48:51 »
Hi
Has anyone got an English version of the becker europa tr service manual?
This link has  one in German but I've tried to translate it and I'm struggling :
https://elektrotanya.com/becker_europa_tr_ab_a50001-700000_sm.pdf/download.html
Thanks!!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
Re: Becker Europa TR service notes
« Reply #1 on: January 12, 2020, 22:26:57 »
col320ce,
Maybe of help: this manual is in pdf that allows to highliht the text, copy it and paste into e.g. Google translator.
Sample:
German
"Die Antennenspannung gelangt über den Trennkondensator C 1 (10 nF) an den Vorkreis, der für MW als πKreis ausgelegt ist. Er wird aus den Elementen C 2 (Antennentrimmer mit 10/60 pF), L 201 (Vorkreis-Variometer)
und der Reihenschaltung von C 203 (170 pF) und C 204
(3 nF) gebildet. Durch den Widerstand R 201 (180 kΩ) läßt
sich der Impedanzverlauf linearisieren. Zudem dient er
der Ableitung von statischen Aufladungen. Mögliche niederfrequente Störungen werden durch die Kombination
von R 202 (8,2 kΩ), C 204 (3 nF) wirksam gedämpft (siehe..."
English:
"The antenna voltage passes through the isolating capacitor C 1 (10 nF) to the preliminary circuit, which is designed for MW as a π circuit. It is made up of the elements C 2 (antenna trimmer with 10/60 pF), L 201 (pre-circuit variometer)
and the series connection of C 203 (170 pF) and C 204
(3 nF). Through the resistor R 201 (180 kΩ)
the impedance curve becomes linear. He also serves
the discharge of static charges. Possible low-frequency interference is caused by the combination
effectively damped by R 202 (8.2 kΩ), C 204 (3 nF) (see..."
Takes 30 seconds.
col320ce
« Reply #2 on: January 13, 2020, 01:41:28 »
That's what I was doing but mine was not making anywhere near as much sense as your translation. It might be due to the way I'm doing it... I'll try again.
Thanks!
Col
1964 230SL
1965 250SE coupe
