Author Topic: Speedometer seal 250LS auto  (Read 1692 times)
TheMadSpoon
  • USA, NC, raleigh
« on: January 16, 2020, 00:39:12 »
Greetings.  Searched and searched, called bud's benz etc.  Anyone know how to seal a transmission fluid leak at speedo cable?  Have new cable, no seal.  Can't seem to locate the part number or come up with another solution.  Thanks!
Re: Speedometer seal 250LS auto
« Reply #1 on: January 16, 2020, 08:29:38 »
WRe
« Reply #2 on: January 16, 2020, 10:29:36 »
sometimes this is a better place to look at: https://www.niemoeller.de/de/w113/w113/B043/260/d26107-dichtring.
Why? Compared to SLS Niemoeller provides in most cases the original MB part number beside their own part number.
...WRe
« Reply #3 on: January 16, 2020, 11:08:43 »
This seal    A007 997 73 46, when you put it in order form shows with 02 at the end, is $4, available 24h.
Definitely it is an advantage of Niemoeller that they provide original PN (outdated sometimes, but it is help). SLS is better at drawings. Niemoeller have MB graphics with a lot of parts not shown. SLS have detailed drawings with early\late versins shown etc.
In this particular example:
- in EPC the seal on speedo shaft comes in repair kit only as per the picture; there are part numbers for a couple of seals that are not on the picture - but you need to know what you are looking for
- without more detailed description it is difficult to pin-point the part (e.g. manual or automatic)
- in Niemoeller it is not on the picture either - you knew what you were looking for, so you found it
- in both Niemoeller and EPC I often just scroll through the part list; in EPC you have the parts tat are not on drawing next to the components they belong to that are shown on drawings
« Last Edit: January 16, 2020, 16:25:36 by Pawel66 »
TheMadSpoon
  • USA, NC, raleigh
« Reply #4 on: January 23, 2020, 01:23:48 »
Thank you SO much.  I searched niemoeller and others but just wasn't sure if that was correct as difficult to tell from the pics.  Again, thanks
Scott
« Reply #5 on: January 23, 2020, 12:25:55 »
Just in case anyone doesn't know, you can also enter an MB part number into both sites and search for it.
