Author Topic: Torques  (Read 2131 times)
Harry
  • USA, TN, Knoxville
Torques
« on: January 24, 2020, 00:26:21 »
1966 230SL Torques
What are the torques for the bolt in the camshaft sprocket bolt?  And how about the crankshaft bolt (with the three spring washers behind the bolt).  The BBB is silent on the camshaft sprocket bolt (or I’m missing it).  I think the BBB says 21 mkp (151 ft lbs) for the “Shoulder screw or clamp nut on crankshaft front”.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Torques
« Reply #1 on: January 24, 2020, 05:19:19 »
1966 230SL Torques
150 ft lbs is correct for the crank screw. Most 1/2 torque wrenches only go to 150 ft lbs and it's really straining your wrench at it's absolute upper limit. I have a 3/4 torque wrench which rarely gets used but it works well in this application.
Harry
Re: Torques
« Reply #2 on: January 24, 2020, 17:27:34 »
Thanks Dan.  I'll check my wrench and may need to borrow a bigger one from Advance.  I'll torque the camshaft sprocket to the same torque I used for the Horizontal Timing Gear sprocket.  Seems like it was 32 ft-lb but I'll confirm.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
mbzse
Re: Torques
« Reply #3 on: January 24, 2020, 17:51:56 »
Quote from: Harry
What are the torques for the bolt in the camshaft sprocket?.../...
Torque value for this one is 80Nm
/Hans S
WRe
Re: Torques
« Reply #4 on: January 24, 2020, 18:07:41 »
Hans is right: 80Nm or 8 mkp (60 ft lb) for the camshaft sprocket bolt and 210Nm or 21+1 mkp (155 ft lb) for the crankshaft bolt for 280SL.
...WRe
« Last Edit: January 24, 2020, 19:39:02 by WRe »
Harry
Re: Torques
« Reply #5 on: January 24, 2020, 20:21:52 »
Wow.  I'm surprised that the sprocket for the HTG is to a lesser value (5 mkp)?  Could you confirm that too, please.  I cannot read the German on this table.  Looks like it is from the BBB though so I'll check there again.
Thanks very much - as always!
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
