Author Topic: W113 propshaft compaibilaty  (Read 2040 times)
Yooks
« on: January 27, 2020, 14:33:19 »
Hi all, I recently bought a project w113 doer-upper. It came with no propshaft. Upon my worldwide search for one, several people had suggested that some w111 prop-shafts would be compatible. Would anyone have some more clarity on that for me please.
Re: W113 propshaft compaibilaty
« Reply #1 on: January 27, 2020, 15:13:17 »
That's correct.
Needs to be shortened though.
 8)
Yooks
« Reply #2 on: January 27, 2020, 16:24:53 »
thank you ;)
450sl
« Reply #3 on: January 27, 2020, 17:33:32 »
And balanced
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #4 on: February 01, 2020, 03:24:29 »
As I understand it almost every model in the era shared the same back section of the driveshaft. The forward section length varied depending on the distance from there to the transmission in each model.
In case you should need to know, the hex nuts where the sections thread together are 42 and 46 mm.
sandcrab59
  • USA, MA, Lunenburg
« Reply #5 on: February 16, 2020, 22:43:06 »
Try Sam In Wisconsin.
Eurocars@itis.com
EurocarsPartz.com
He might have the front driveshaft you are looking for .
Also the rear shaft.
I purchased a complete driveshaft a few years ago.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
