Author Topic: Battery Cable Supports  (Read 2585 times)
Harry
  • USA, TN, Knoxville
« on: February 01, 2020, 02:27:30 »
Interesting question in that I don’t recall ever seeing a post.  There are several eyelets with rubber insert mounted around the oil pan that the battery cable going to the starter threads through.  I have one eyelet a little different than the others and instead of having a hole to mount through to the pan, it appears as though it mounts on the sheet metal somewhere in the engine compartment?
So where do all of these mount?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Battery Cable Supports
« Reply #1 on: February 01, 2020, 03:46:09 »
Closest to the battery is the one that clips onto the battery tray.  I will see if I have a picture of the rest.
« Reply #2 on: February 01, 2020, 10:08:55 »
It is the blue one at at the bottom of the battery. Attached to the battery frame.
Harry
« Reply #3 on: February 01, 2020, 11:48:29 »
That's it!  Thank you!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
« Reply #4 on: February 02, 2020, 15:35:20 »
Question: is blue the original color for this grommet?
« Reply #5 on: February 02, 2020, 16:40:46 »
I do not know, I doubt it. But this is what you get from Mercedes today.
« Reply #6 on: February 02, 2020, 21:13:47 »
The original was black and you can get a suitable replacement from Mercedes: p/n 110 997 0481
For discussion see: https://www.sl113.org/forums/index.php?topic=13803.msg93746#msg93746
« Reply #7 on: February 02, 2020, 21:49:34 »
Thanks Alfred, yes I just checked, it is still available for  €2,52 in Germany
« Reply #8 on: February 03, 2020, 19:49:27 »
Here is the rest.  Hard to see the last one just ahead of the engine mount on the engine block to upper pan bolt.
johnk
  • USA, OH, Avon
« Reply #10 on: February 04, 2020, 12:03:04 »
Buds has black grommets for $8 each.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
