Sorry - Cees is correct. I see that acronym so much on the Forum that I just assumed it was commonly understood. (I'll do better on subsequent posts.) Upon closer inspection, the torque of the 22mm Fitting does not impart a load on the VTG. The Fitting threads into the Thrust Piece which is secured to the block with a 10mm bolt.
Harry
