Author Topic: Urethane suspension bushings - NOW READY!  (Read 42848 times)
russelljones48
  • USA, NC, Mooresville
Re: Urethane suspension bushings
« Reply #25 on: February 05, 2020, 23:26:29 »
OK, so according to Wikipedia here's the definition of a durometer - it's analogous to the Rockwell scale for metals...
The durometer is a device for measuring the hardness of a material, typically of polymers, elastomers, and rubbers. Higher numbers on the scale indicate a greater resistance to indentation and thus harder materials. Lower numbers indicate less resistance and softer materials.
« Reply #26 on: February 10, 2020, 23:46:33 »
I dealt with rubber and urethane for 35+ years so, I can help with some of the questions. I am still trying to get more info in regards to the existing tooling before I buy it.
Hardness of rubber is measured with a spring loaded pin. How deep it goes determines the hardness. The deeper the pin goes, the softer the material. There are at least 4 ranges of hardness and is measured with a durometer. Shore has A, B, C and D scales. Shore A and D are by far the most common ranges. They overlap and there is a reason for that. At the outer ends of the scale, the measurement becomes less accurate. So the optimum accuracy is in the middle of the range. You can google it and see what I am talking about. So a 70 Shore A rubber is a very common hardness and what most O-rings are.
But, when you squeeze and bend rubber, that is NOT the hardness you feel but rather Modulus. Modulus is very commonly mistaken for hardness. "An elastic modulus is a quantity that measures an object or substance's resistance to being deformed elastically when a stress is applied to it". Not my words but that is what it is.
A good example is that urethane has a much higher modulus than would common rubber. That is the property you are after for suspension bushings. Compare a 80 Shore A urethane to 80 Shore A rubber and you will find the rubber bends much more easily. Yes the harder the material the somewhat stiffer the material feels, but modulus is more important here.
That being said, I could see using a range of 85 Shore A to 95 Shore A urethane. Any softer than 85A, you aren't really gaining much over OEM rubber. 95A is hard as a rock and most would call a plastic. Plastic BTW, is usually measured in the Shore D range. 95A is equal to 55D as a reference.
I am not however an expert in suspension systems and I could see experimenting with hardnesses. Yes, I think you could offer a mild upgrade and then the higher performance bushings. Each with its own pros and cons. That would not be an issue in production to do so.
russelljones48
« Reply #27 on: February 11, 2020, 15:50:52 »
thanks for the explanation - it's helpful..  Can't wait to see what you come up with.  I think modern bushings would be a GREAT addition to what's available for our ;D cars..  And they will not affect the car's originality if someone wants to revert to original rubber.  I've got the Koni adjustables and a set of aluminum rims and I'm quite happy with the results to the handing.  Can't wait to add to the tricks..  ;D
« Reply #28 on: February 11, 2020, 23:17:38 »
I can tell you that the Cox bushings were hard. Like hockey puck hard.
jond907
« Reply #29 on: February 12, 2020, 00:19:02 »
Interested!
pedrocamp
  • Charlotte NC
« Reply #30 on: February 12, 2020, 13:02:18 »
Even more interested, thanks! Glad to see you know the materials, hope the molds work out.
Mobil-Werks
Classic Sport and Specialty Automobile Service
Garage and Workshop "House Calls"
« Reply #31 on: February 13, 2020, 04:53:53 »
Cox bushings were 95 Shore A. If I had to start today, I probably wouldn't go above a 90 A. 5 points do not seem like much on paper, you you can feel the difference. I would like to experiment with both 80 A and 90 A. 80 A would give you a bit of an upgrade and 90 A even more. No two people are alike and want the same thing.
« Reply #32 on: February 27, 2020, 22:01:59 »
The tools for the urethane suspension bushings are on the way!!! It looks as though I will be making these at some point soon. For the W113 Pagoda and W111 cars, the following will be available:
- front flat leaf spring
- Front sway bar (frame and end link)
- Rear axle trailing arm (frame and axle)
I have quite a bit to do and am looking at these being available in the summer or early fall. My initial plan is to make these ever so slightly softer. I think that will be a better fit for the Pagoda crowd, rather than the very hard compound used prior. But, we shall see.....
pedrocamp
  • Charlotte NC
« Reply #33 on: February 28, 2020, 21:40:22 »
Good news!
Mobil-Werks
russelljones48
« Reply #34 on: March 08, 2020, 19:43:16 »
I agree - great news!!   Can't wait to get my set...
« Reply #35 on: June 15, 2020, 16:17:58 »
Getting closer. I have produced parts from each tool and they match the OEM in fit and dimension. The hardness is a bit softer than what Cox had. His was 93 to 95 Shore A and mine are 88 Shore A. Does not sound like much of a difference, but you can feel it being a bit softer. I think that hardness is a good compromise between performance and ride comfort. The last step in the process was to surface cut the "open pour" side flat. Sounds easier than it is, but that is now under my belt.
Shown is a rear sway bar bushing for the W112 and W109 cars with air suspension. For the W113, I have both front and rear trailing arm bushings for the rear axle, the front flat spring bushings and the front sway bar bushings.
Just a few more details to hammer out and they will be ready!
mrtzmd
  • USA, CA, OCEANSIDE
« Reply #36 on: June 16, 2020, 06:14:17 »
Just saw this thread. Interested.
russelljones48
« Reply #37 on: July 21, 2020, 22:23:59 »
Still interested.  Next big project on my car will probably be all the body/engine rubber..
Rahul
  • Bermuda, Devonshire, Paget
  • 1971 280SL automatic #571, parchment
« Reply #38 on: October 28, 2020, 07:27:25 »
I might have interest in these!
1971 280SL auto #571 over parchment
« Reply #39 on: October 28, 2020, 17:09:56 »
They are coming along and I have a test bed scheduled on a 6.3 W112. Once that is done, they will be ready for sale. I have the full tooling for the W113 cars as well as anything made in the 60s. (not W100 though). I typically sell through one of the well known Mercedes parts suppliers to help simplify on my end. I am thinking by mid-November they should be ready to go. Thank you for your patience and want to make sure I get this right the first time.
russelljones48
« Reply #40 on: October 30, 2020, 15:39:42 »
can't wait!!  a winter project  ;)
« Reply #41 on: November 21, 2020, 04:05:28 »
It's been quite some time since I've been under my Pagoda.  What is this front flat leaf spring you talk of?  I don't remember it.
« Reply #42 on: November 21, 2020, 04:34:40 »
That is the "leaf spring" that mounts to the front of the chassis and then to the subframe. There are (4) bushings mounted there and this for the castor adjustment I believe.
BTW, getting close with production on these urethane bushings. I am taking great pains to make sure these are right the first time. I will post when they are ready to go.
tedskeff@icloud.com
« Reply #43 on: January 10, 2021, 03:24:17 »
Am very interested as it's time to change all of mine.
« Reply #44 on: January 10, 2021, 04:16:57 »
I have unfortunately been delayed on the start up for the bushings. 2020 has been a tough year to get loose ends tied. I am waiting on tooling that will allow me to finish the final production work. Once I get that, they are ready to go. Best date right now is mid January. So pretty close. I will post here when that happens. Thanks for your patience.
Re: Urethane suspension bushings - NOW READY!
« Reply #45 on: February 23, 2021, 17:31:09 »
It has been a year since I started this project and now we are ready to go. I am selling these through Miller's. These are not currently set up on their website, but they have committed to stock parts for the Pagodas. Attached are a couple of pics of the parts that are available at the moment. To order sway bar parts, the diameter of the bar must be known. Other than that, it is pretty standard.
PM me if you have questions.
russelljones48
« Reply #46 on: March 06, 2021, 19:36:09 »
what's the price for a set?  I can't find anything on Miller's
« Reply #47 on: March 07, 2021, 02:00:53 »
PM sent.
Rahul
« Reply #48 on: July 29, 2021, 00:35:09 »
Curious, has anyone managed to try these out yet?
My bushings are up for replacement and I am debating whether to just stick with the OEM rubber, or try something different and longer-lasting. I am not going to have the time (or skill) to try out different setups for front/rear etc - so really looking for any recommendations on whether these are worth installing 'out the box'. If it purely comes down to experimentation or matter-of-taste I'll probably stick with OEM.
For ref, mine is a 1971 280SL, thanks.
bonbahn
  • USA, TX, Houston
« Reply #49 on: June 07, 2023, 14:15:40 »
This is an older thread, but it's how I found this product. I bought the urethane suspension kit for my W109.018 6.3 from Miller's https://millermbzparts.com/109-URETHANE-SUSPENSION-KIT/32-8101U .
I installed the 6 bushings on the rear torsion/sway bar. I had to cut 2 of them longitudinally with a hacksaw blade to slip them onto the sway bar. Pressing the bushing on the car for the upper holders required a long bolt and series of sockets and washers - no problem really. Pressing the bushing into the lower holder was okay, but required a ton of cleaning. It helps to deburr the metal parts and sand/file a slight chamfer on the urethane bushing's inner/outer diameter. Pressing the sway bar into the lower holder was a nightmare. I'm not a mechanic. This is supposed to be fun. It kicked my butt.
To press the sway bar onto the lower right holder, I got it started by hand then beat the hell out of it with a rubber mallet with the sway bar in a vice. The left holder has to be installed on the car, then the left end of the sway bar needs to be pressed in just the right amount for you to bolt the right side holder back in place. It is very hard to do this with the tires on. It is very hard to do this with the vehicle on jack stands because you're fighting the suspension geometry. Let all of the air out of the system, zip tie the sway bar to the upper holders, remove the rear left tire, wrap a ratchet strap around the holder and sway bar, and press until the right side holder can be bolted in place. Bolt the torsion bar upper holders, then test drive and retighten everything. You might as well plan on replacing the rear shocks because you'll need to remove them and reinstall them anyway.
The kit did not include the bushings for the 6.3's antidive bar. I probably could have bought another set of urethane front sway bar end links, but instead I bought an inexpensive rubber kit from Niemoeller that included a new bolt and sleeve. As far as I can tell, rubber might be better on the antidive because it's just up and down forces with no side-to-side movement. Tip: Mount the bolt facing up and use a jack to press it into the body so you have enough threads to start the nut under the rear seat.
The front sway bar was much easier and very straightforward. I chickened out on the rear trailing arms and front leaf spring bushings. I might do those later. The kit comes with good grease, and I used all of it just on the sway bars. No squeaks.
The ride is so much better. 4 passengers used to roll quite a bit and the car has flattened out beautifully. I don't notice much difference in stiffness/bounciness. Huge thanks to wwheeler for having the means to create this kit. Definitely worth it.
