Author Topic: Cracks on steering wheel repair  (Read 3033 times)
Gazoo
« on: February 05, 2020, 07:45:07 »
I have a black 69 seering wheel with cracks ,is it a good idea to fill thrm with black epoxi glue and then poish the wheel?
I know is ebonite and never did something like this before
My idea is only put epoxi into the cracks and after two days polish it with a 2000 sand paper
Any sugestions as i dont want to paint the whole wheel
Thank you
WRe
getsmart
Re: Cracks on steering wheel repair
« Reply #3 on: February 05, 2020, 19:52:51 »
I've repaired mine exactly the same way. As long as the cracks have not compromised the strength and integrity of the wheel it should be ok.
Good luck!
Rgds,Joe
Finding the red car
« Reply #4 on: February 05, 2020, 20:44:02 »
Joe,
Did you repaint the whole wheel after repairs?
1972 MB 280CE Auto RHD 906G
2024 Volvo EX30 Electric
getsmart
« Reply #5 on: February 06, 2020, 04:43:32 »
Not yet Garry!!! Have repainted at all but will do at some stage before she all goes back together
Finding the red car
wayne R
« Reply #6 on: February 06, 2020, 05:52:09 »
Just a few other tips  for anybody restoring  steering wheels,
1---remove wheel from car.
2---lightly sand whole wheel with wet @ dry  paper about 120-200,dont rub to hard so not to damage grooves.
3---Fill all cracks , holes ,etc, with filler .Using a epoxi glue filler has a couple of problems, it is very hard so its harder
to sand and get the required finish ,not like ordinary fiber glass body filler that has very good sanding qualities, and the epoxi
is not as acceptable to some paints when painting.
4---Sand the filled wheel with about 220-300 until whole wheel is filled and smooth, may require  2 gos at this.
5---clean whole wheel with a paint prep degreaser.
6---1st coat using-- acrylic primer surfacer-- whole wheel about 2 or more thin coats until wheel is completely smooth,
about 4 minutes between coats.
7---After about 30 minutes sand with  320-400 wet @ dry until smooth,---.
8---Now paint 2 coats with colour about 4-5 minutes between coats
9---Wait about 10minutes then finish with  2 or 3 coats of clear about 4 minutes between coats.
10--- the next day can cut and polish with  Meguiars etc if you are really particular,this job can be done
in half aday, and only paint on hot,sunny, no wind day,at about 85-90 degress,and only use
same product with the three paints used.
I did mine about 3 months ago ,and its about 90 percent better,as i got lazy in the end,prep  properly to get best result,
mine had big deep cracks especially at 12 oclock facing the windsceen, was lazy as my car is not show, regards.
« Last Edit: February 06, 2020, 08:03:22 by wayne R »
wayne R
« Reply #7 on: February 06, 2020, 05:55:55 »
Couple of photos ,sorry i never had many photos before.
« Last Edit: February 06, 2020, 06:07:16 by wayne R »
wayne R
« Reply #8 on: February 06, 2020, 06:00:52 »
Finished  photos.
Gazoo
« Reply #9 on: February 06, 2020, 08:14:44 »
Thanks everyone for your help .
I will do mine and i will tell you how it went
Sincerely
« Reply #10 on: February 06, 2020, 09:30:13 »
I think a good winter job.
