Author Topic: Pictures of Engine and Transmission  (Read 2203 times)
Harry
  • USA, TN, Knoxville
« on: February 07, 2020, 02:37:46 »
I am going to mount the transmission (automatic) to the engine this weekend, and hopefully get the unit in the car.  You have the transmission, the spacer plate (aluminum) and the engine.  I'm wrestling with the bolts.  The upper two go through the transmission and spacer plate, then thread into the block.  Then there are the two that secure the starter and thread into the starter flange.  Two more go through the "wings" on the oil pan and appear to require a nut on the ends.  (There is no threaded hole that they go into.  Then there is another bolt the looks like it goes through the transmission and spacer plate only.
I have myself confused a bit.  Does anyone have some pictures that show the assembled unit (engine with transmission)?  That would be very helpful.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Pictures of Engine and Transmission
« Reply #1 on: February 07, 2020, 03:16:54 »
Here is one of the engine and transmission connected for my 230sl, I unfortunately don’t have one from the other side or below.
mbzse
« Reply #2 on: February 07, 2020, 08:38:20 »
one view here
/Hans S
Harry
« Reply #3 on: February 07, 2020, 13:34:28 »
Thanks gentlemen!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
WRe
« Reply #4 on: February 07, 2020, 15:37:39 »
maybe this picture helps too because you can "see" holes and threads.
...WRe
Harry
« Reply #5 on: February 08, 2020, 20:33:57 »
All a great deal of help.  Thanks again!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
