Author Topic: Flywheel protection cover plate  (Read 1982 times)
alpina
  • Spain, Asturias, Villaviciosa
« on: February 07, 2020, 16:46:30 »
I have just become aware that i am missing the flywheel protection cover plate (shown in the picture below). I have now ordered a replacement from SLS. However they do
not have the fixing bolts. MB have the smaller bolt and the washer for the larger bolt, however the large bolt is not available. The part no of
the larger bolt is N000933010111
Does any one know anywhere in Europe where i could find one. failing that does any one know the size and length of this bolt. i think one online
part site indicated a M10 x 12 but i would like clarification. The bolt in question is circled in the image below.
Re: Flywheel protection cover plate
« Reply #1 on: February 07, 2020, 18:34:26 »
It is a standard M10x12 bolt. Steel grade 8.8, also very typical.
The number with N.... means it is standard (normal) item. Then you just have to decode the DIN number.
« Reply #2 on: February 07, 2020, 21:33:40 »
Find the shortest one you can and then cut a bit off if you have to.
1988 560SEC
johnk
  • USA, OH, Avon
« Reply #3 on: February 08, 2020, 02:04:10 »
try Boltdepot. They sell bolts one at a time with a large selection and no minmum order,
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #4 on: February 08, 2020, 09:12:46 »
Sourcing in Europe:
- DIY stores
- nearby mechanic - I am sure if you ask nicely they will help
- internet stores
Just google "screw M10x12".
If you cannot find exact length and you decide to cut it, put the nut on above the cutting place, so when you screw the nut out after cutting it will shape the thread. If it is a steel screw you may put some paint on the cut end to prevent rusting.
I would probably consider a stainless steel one, but that is only me.
alpina
« Reply #5 on: February 08, 2020, 14:01:53 »
Thanks everyone. i have now found an M10x12 bolt. another question, any one have any detail on the other bolt
highlighted in the new picture. Thanks.
