Author Topic: Soft top inesthetic....!  (Read 1920 times)
yves
  • France, Poitou-Charentes
« on: February 08, 2020, 21:48:49 »
Have you a trick avoiding that :
Re: Soft top inesthetic....!
« Reply #1 on: February 08, 2020, 21:55:33 »
When you fold your top down into the compartment, you need to make sure that the outer edges are pushed down under rather than up that naturally happens when it drops into the HT box.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #2 on: February 08, 2020, 22:29:49 »
Hi Yves - when you search the forum and the technical manual, you will find many discussions about this. It is as Garry says. In fact I had to start 'alternating' methods because the corners on my top started to curl down/inward rather than upward.
yves
« Reply #3 on: February 09, 2020, 10:58:25 »
Thank's Gary and Cees …..Apologies , i should have read the manual before posting... :-X  many info available..
mbzse
« Reply #4 on: February 09, 2020, 11:51:46 »
Quote from: yves
.../... [tech manual] many info available..
Yes Yves. During the 17 yrs of this Forum, quite a number of Pagoda related subjects have been milled through...  8)
A substantial Body of Knowledge (Pagoda BoK)
/Hans S
WRe
« Reply #5 on: February 09, 2020, 15:55:05 »
It helps when you lay a piece of plastic over the fender before you close the softtop so the edge can slip in better.
You can see it here:
http://w113.eu/geschlossen/Optimierungen/schliessungshilfe_fuer_das_softtop.htm.
...WRe
mbzse
« Reply #6 on: February 09, 2020, 16:51:26 »
A useful video, also showing such a "shoehorn" to protect the rubber seal when lowering/raising soft top:
https://www.youtube.com/watch?v=dcvG2HfMat4&t=99s
Is in a parallel Forum thread:
https://www.sl113.org/forums/index.php?topic=30389.msg220334#msg220334
« Last Edit: February 19, 2020, 01:39:32 by mbzse »
/Hans S
