Author Topic: Clips to rubber window seals on both tops.  (Read 1531 times)
Mike H
  • Australia, New South Wales, East Ballina
« on: February 09, 2020, 04:14:14 »
Just replaced the window seals on the softtop, and remember a few clips that supported the ends 0f some of the rubbers.
The old ones I removed are a different shape to a couple I bought recently, but look to do the same job.
Are there different clips for different positions to the seals around the window ?
I also need to know the number of clips required, per side, for:
1    Seal to windscreen pillar........
2    Seals to top of window for softtop.....
                                       for hardtop....
3    Seal to rear of window for softtop.....
                                       for hardtop....
Thank you for any help,
Mike
mbzse
Re: Clips to rubber window seals on both tops.
« Reply #1 on: February 09, 2020, 12:33:07 »
Quote from: Mike H
.../...clips that supported the ends of some of the rubbers.../...
I suppose you refer to these? One each side on A-pillar, one each side on HardTop upper seal.
Could be some extras, too
See this thread:
https://www.sl113.org/forums/index.php?topic=13160.msg89386#msg89386
« Last Edit: February 16, 2020, 00:14:37 by mbzse »
/Hans S
