Become a Full Member and get the official Linkage Tour and the official Starting Aid. This information alone will pay for your membership
Hi,I assume you are looking for this grommet, see att. picture.I couldn't find any part number or other details, sorry.I would look for a "universal" grommet in a hardware store. What's the size of the hole and hose?...WRe
I used a 1/2'' hose
Keep in mind that MB has never made their own AC units. They used York, GM, Nippendenso, and maybe others so they made their builds adapt to the AC pump.
Hi Dr Benz,We are only discussing the evaporator drain hose (Frigiking) grommet in this discussion. I’m trying to find out where I might be able to get a replacement for the 1 3/4” “Skirted Grommet” that goes through the floor in the front right corner of the passenger foot well. It is where the drain hose for the output of condensation from the Frigiking evaporator goes to the street.I’d also like to know the correct size for the drain hose, ID and OD.Best,RolandI’m trying to find
Solution is simple.Measure evaporator core drain hose attachment.Select appropriate size hose.Measure hose ODFind appropriate grommetDrill appropriate hole in floor.
Hi,Sorry but I don't know what a "skirted" grommet is, maybe like this: https://www.oldtimerbedarf.de/gummi_5 ?...WRe
A similar “skirted” drain grommet is used in the soft top compartment. Not sure on the size though.
Hi,Ok, I understand a "sleeved" grommet but it will be hard to find it with 1 3/4" size.I don't understand why it must have a skirt/sleeve because the drain hose is a skirt/sleeve itself. The hose needs only a protection for the metal hole means a simple grommet....WRe
