Author Topic: Why Am I Seeing This?  (Read 3232 times)
JoeTroise
« on: February 21, 2020, 18:47:55 »
As an appraiser, I have noticed on more than one occasion that some pagodas show a "10" in the VIN but are in fact, automatics. The database here suggests that an automatic car should have a "12" in the VIN.
I have heard mention that a Euro-spec car can carry the "10" in the VIN and yet be an automatic, whereas U.S. cars would show the "12".
Any comments on this?   Thank you!
Re: Why Am I Seeing This?
« Reply #1 on: February 21, 2020, 19:15:35 »
MB wouldn't make a mistake like that. I'd say it's safe to assume that someone changed the transmission.
JoeTroise
« Reply #2 on: February 21, 2020, 19:57:39 »
So one would think, but why on so many SLs over the past few years? It kinda doesn't make sense that we'd be seeing so many switched transmissions, especially since the manual trans cars are worth more.
Thanks for your reply.
kampala
  • USA, CA, Beach Cities
« Reply #3 on: February 21, 2020, 20:04:37 »
Did it occur to you that maybe the trans was not changed but the VIN was from another car?
250sl - later - manual
280sl - 1971 - Auto - LSD
JoeTroise
« Reply #4 on: February 21, 2020, 20:15:03 »
Yes that did occur to me, but here again--so many times? The VIN plates don't "look" molested, and other panels, like the hood, match the VIN #s. (body number)  But yes, many SLs have had distressed past lives, and most of the SLs I appraise are not original cars anymore. I've seen them from magnificent to horrifying.
« Last Edit: February 22, 2020, 17:20:28 by JoeTroise »
« Reply #5 on: February 21, 2020, 23:48:05 »
... but why on so many SLs over the past few years? ....
How many is "many"? 5 per 10 years, or 100 per 10 years?
kampala
« Reply #6 on: February 22, 2020, 15:58:13 »
The hood number and other panel numbers on the vehicle never match the VIN.   Body numbers are not connected to VIN.
This said, I have heard of couple of cars that have been converted to Auto - even though Manuals might be worth more recently, many many years ago, autos were preferred more.
JoeTroise
« Reply #7 on: February 22, 2020, 17:33:15 »
Well for the year 2019 I inspected  5 280SLs, and 2 of them had this VIN anomaly. The other 3 were manuals and had the correct sequence "O".  So all 5 had "O" in other words.   I haven't checked my files going back further, but I'm sure I recall a few others.
JoeTroise
« Reply #8 on: February 22, 2020, 17:36:50 »
Yes, that's right, body number.  I suppose the transmission swap is the most plausible explanation.
Here's an example of one I just looked at last week. This is an automatic:
JoeTroise
« Reply #9 on: February 22, 2020, 17:42:42 »
Here's another from a few months ago, also an automatic car:
MikeSimon
  • USA, OH, North Royalton
« Reply #10 on: February 22, 2020, 17:43:39 »
I want to say the plate was replaced, because it was not "affixed" with Philips screws, but riveted.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
kampala
« Reply #11 on: February 22, 2020, 18:01:18 »
Mike,
the plate with the "screws" appears to be a Euro model - since the plate is on the firewall - and these typically had screws.  The USA models with VIN plates  in door jams had rivets.
« Reply #12 on: February 22, 2020, 18:30:28 »
Joe,
Do you also compare the VIN plate # to the VIN # stamped in the right front frame rail below the intake pipe?
JoeTroise
« Reply #13 on: February 23, 2020, 19:21:11 »
No, but I will next time. I just wasn't on guard for VIN plate switching until these multiple examples started popping up.  This always seems to happen with certain "classics"---once the value becomes substantial, all kinds of monkey-business begins. I've seen Porsche 356s that were actually two cars welded together, so your suggestion is not improbable.  The one possible "Euro" car noted was rather butchered, that's for sure.
