Author Topic: lenght of the pin operating the turn signal in the steering switch  (Read 7302 times)
yves
  • France, Poitou-Charentes
I am trying to repair my steering column  switch which does not hold when i turn the flasher on the right or left. As i read on different discussion it seems that i must lenghthen the pin . Does some one can tell me what is the right lenght of the pin ?  too long it will be too fragile
Actually the pin is about 1 mm out of the edge of the switch case  as the photo below shows and i have not a big lenght available too glue some thing :
Advices will be much appreciated …  ;)
« Last Edit: February 22, 2020, 21:26:18 by yves »
Re: lenght of the pin operating the turn signal in the steering switch
« Reply #1 on: February 22, 2020, 19:03:41 »
To fix mine I heated up a pair of duck bill pliers with a torch and gently squeezed the pin to slightly elongate it. It doesn’t take much. That was 5 years ago. Still working great.
« Reply #2 on: February 23, 2020, 05:00:46 »
The "not holding" problem is usually caused by the roller assembly. Often times the soft metal raceway the roller rides on becomes more level over time and usage. The little "valley" catches and holds the roller so the turn signal stays on until the turn is completed. Carefully re-storing the "valley" with a Dremel can restore its function. Making the "valley" too deep can make difficult to self-cancel, so go carefully.  In addition there are various other circumstances and problems which can add to the "not holding" problem if this is not the case.
yves
« Reply #3 on: February 23, 2020, 14:42:00 »
I have solved one side of the issue with "gluing" the short pin with some bondic :
 It seems solid after some trys in rotation with my finger. I fitted the switch case back on the steering column and it works……  I'll see if it is a good solution afetr some use   ::)
yves
« Reply #4 on: February 23, 2020, 22:13:51 »
I had a surprise when i fitted back the switch o the column:
The washer was lying on the case when i screwed it ….! so i decided finaly to dismantle all the switch on a Bench clean and prepared to prevent any spring detend unexpected... ::)
I took many photos which should be useful for anyone …. in case !
Now i have to replace the 2 "rivet pins " which hold the arms actuating the rollers.
yves
« Reply #5 on: February 28, 2020, 21:00:30 »
I have dismantled all the parts for refurbishing and replaced the two "rollers" by some new rollers cylindres made from a steel rod ….. and then drilled the pivots of the levers operating the levers,   threaded the case for 2 new 4 mm screws, modified the head screws  so they can be placed in the right position . Putting the levers springs was not very easy , and i finished fitting all the switch on the steering column :
« Reply #6 on: February 29, 2020, 17:02:20 »
amazing write up and photos.  thank  you very much for sharing
yves
« Reply #7 on: February 29, 2020, 22:03:17 »
I had a surprise when i have tried the switch on the column…. During the refurbishing the modified elongated pin i have put with bondic  was broken when i pressed on the shaft against the strong ball spring… to screw it on the case . But i fitted the switch on without another repair. And it works …! because the part where the pin is  located is now free of a complete  move . So the pin is now actuated by the column .
yves
Hum…… after fitting back the switch on the column, it worked fine when i pushed down or up the lever. The lever came back on the neutral position in the  2 position while i was turning the steering Wheel. But after connecting the 12 pins plug Under the dash all the lectric functions were ok ...except the turning lights ! :-[
So i dismantled again the switch and put it on the Bench and saw that there was no contact between the copper part with 2 contact pins and the 3 copper contact on the other side :
So i thought that the 2 connect pins were too much flat . I put on those pins a little drop of solder wire  and grinded them until they have what i thought the right thickness:
After a Bench test …. it didn't work…. !
A good inspection helped to find the solution…. I have fitted the copper plate with it's two pins in the wrong position. I thought that the curve edge was outside …. It is not  . So i turned the plte on the other side and tested it on the Bench : all was fine !
The photo below shows the plate on the WRONG side
The good news  is  that now the lever is no more  light to moove because of the drops on the pins
Rahul
  • Bermuda, Devonshire, Paget
  • 1971 280SL automatic #571, parchment
This had to be one of the best posts I have come across on this forum. Thank you!!
I managed to fix an issue with my turn signal using this guide (with help from a few other posts)... I sincerely hope this is the hardest DIY fix I will have to do because it was an absolute pain in the @$$!!
Never again, lol
1971 280SL auto #571 over parchment
Great presentation post on the turn signal switch repair.
Yves, will you load it into the technical manual for others for future reference please.
yves
Hi Garry it would be withe pleasure but i don't know how to do that ....! :o
Yves, you've done it before. Check the end of: https://www.sl113.org/wiki/Electrical/SteeringColumnSwitch... oh no, I see that it was done by Wre.
And... Help is here: https://www.sl113.org/wiki/Main/News
I would recommend that you add it because your pictures are hosted on a third party site, and my get lost to us in future...
getsmart
  • Australia, Victoria, Dromana
Great work Yves, I'm about to get stuck into mine!!!!
Rgds, Joe
Finding the red car
1964 230sl Restoration Project
