Hum…… after fitting back the switch on the column, it worked fine when i pushed down or up the lever. The lever came back on the neutral position in the 2 position while i was turning the steering Wheel. But after connecting the 12 pins plug Under the dash all the lectric functions were ok ...except the turning lights !
So i dismantled again the switch and put it on the Bench and saw that there was no contact between the copper part with 2 contact pins and the 3 copper contact on the other side :
So i thought that the 2 connect pins were too much flat . I put on those pins a little drop of solder wire and grinded them until they have what i thought the right thickness:
After a Bench test …. it didn't work…. !
A good inspection helped to find the solution…. I have fitted the copper plate with it's two pins in the wrong position. I thought that the curve edge was outside …. It is not . So i turned the plte on the other side and tested it on the Bench : all was fine !
The photo below shows the plate on the
WRONG side
The good news is that now the lever is no more light to moove because of the drops on the pins
