Do I recall correctly that the front engine seal lip actually rides on the space ring/collar, and not on the crankshaft itself? And that the spacer/collar needs to be sealed where it slides over the crank shaft so oil doesn't leak out between the two? I'm working through sealing up the oil leaks on my engine, and this is coming up on the work list.
