Author Topic: Jammed hatch cover on 1969 280SL  (Read 5317 times)
rutger kohler
« on: March 05, 2020, 07:26:55 »
Hi, I put my soft top away properly, about a week ago, but now the right hand side of the hatch cover won't release. The soft top was stowed properly and the release cable is not broken. Using a torch, I can see the cable is working against the spring, on the right hand side but it is not releasing the right hand catch.  I have tried to remove the large chrome cover in this area, which would allow me access, however there are two phillips screws that can't be removed without the hatch cover up.
I have looked at the technical manual but can't anthing that will help relause the right hand side.
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
Re: Jammed hatch cover on 1969 280SL
« Reply #1 on: March 05, 2020, 08:14:24 »
Rutger,
 Try having someone pressing down on the cover on the side not releasing whilst you pull the release lever.  That may release the catch if there is upward pressure from the soft top on the cover
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #2 on: March 05, 2020, 09:12:32 »
Yes, as Garry describes, I had a similar thing, it was the question of adjustment once it was open - too much slack on the cable. Pull the lever while someone is pressing the right hand side of the hatch. press where the leather is to avoid the dent on aluminum surface.
mbzse
« Reply #3 on: March 05, 2020, 12:23:17 »
In the Forum Technical Manual, under section "Top/Soft Top" there are some tips and pictures under a heading: "What if your release handle does nothing anymore?"
Also some tips in this thread:
https://www.sl113.org/forums/index.php?topic=16952.msg178065#msg178065
« Last Edit: March 05, 2020, 12:35:34 by mbzse »
/Hans S
rutger kohler
« Reply #4 on: March 06, 2020, 20:19:27 »
Hi, thanks for the suggestions, I have tried having someone pushing down on the right hand side of the hatch cover, as the release lever is moved, but alas, this doesn't work. There is absolutely no give on the right hand side,
It's frustrating because, with a torch, I can look down throgh the slots in the large chrome fitting and see the cable working against the spring on it, on the right hand side.
1972 280SE 3.5 auto
rutger kohler
« Reply #5 on: March 07, 2020, 06:37:31 »
A photo of the right hand side with the hatch open, showing the catch arrangement would be really handy
1972 280SE 3.5 auto
« Reply #6 on: March 07, 2020, 08:50:11 »
Is it not the photo within the link mbzse provided that you need?
« Reply #7 on: March 07, 2020, 09:42:56 »
I think this is the ones from Alfred’s post.
johnm
  • Canada, NS, Lawrencetown
« Reply #8 on: March 07, 2020, 14:00:30 »
 unfortunately had this same issue and had to cut a small hole in the sheet metal to enable us to access the release. Once done and the latch adjusted the hole was easily patched (welded) and of course would never be seen once the carpet/upholstery was in place. Nonetheless a frustrating encounter.  Good luck?
1966 250S
« Reply #9 on: March 07, 2020, 14:41:21 »
It is possible to get a "L" shaped tool down into the hinge area and release the latch without cutting any holes. I'll try to post some photos.
mbzse
« Reply #10 on: March 07, 2020, 15:17:53 »
Quote from: ja17
It is possible to get a "L" shaped tool down into the hinge area and release the latch without cutting any holes../..
Some pictures and info here (courtesy of Wolfgang):
http://w113.eu/geschlossen/Optimierungen/Notoeffnung%20Verdeckkasten%20Mercedes%20Pagode%20W%20113.htm
A short film clip here:
http://w113.eu/geschlossen/Optimierungen/schnapper2.avi
(Emergency opening in seconds. I always carry this tool/handle in my SL, for me or for benefit of SL buddies)
/hans
« Last Edit: March 07, 2020, 15:24:08 by mbzse »
/Hans S
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #11 on: March 07, 2020, 16:05:28 »
Thanks for posting that Hans👍  That's a great little tool.  I'm off to Home Depot 😜
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
johnm
« Reply #12 on: March 07, 2020, 16:59:42 »
 Wow. wish I had thought of that. Excellent!
1966 250S
Norm
  • USA, TX, Wimberley
« Reply #13 on: March 07, 2020, 17:25:54 »
Can someone post what that tool would be called and where one might purchase?
Norm
Norm
1966 230SL 162H Blue-Grey
1994 Acura NSX Formula Red
2024 Acura RDX A-Spec, White Pearl
2016 Mercedes S63 AMG Coupe Obsidian Black
2011 Harley Davidson Super Glide Light / Dark Root Beer
« Reply #14 on: March 07, 2020, 18:09:57 »
This happened to me once before a few years back, and there was a post I made about this.
The CAUSE was a nut had come off the shaft, thus not allowing the shaft to turn or engage the release.
The SOLUTION was a 5 minute job at my friendly local (well, they are not so local any longer >sigh<) independent, Motorwerks in Commerce Township, Michigan. They got a piece of old brake line, (probably off some Porsche) bent it to form a J-hook, inserted into the compartment from the trunk (boot) where the hinges are, and pulled the release.
Voila. Done.
Once released, they affixed the nut back with Loctite, maybe a new lockwasher and said "It will NEVER come off by itself again".
mrfatboy
    • Mrfatboy
« Reply #15 on: March 07, 2020, 19:03:34 »
Well that was simple and quick. 🤣  I had the parts in my garage.  Added an old gear shift knob for style points🤣
PN 113-1337-7001 🤣
Signal Red
4 Speed
« Reply #16 on: March 07, 2020, 20:07:26 »
Well done Mr. Fat Boy!  I admire the style points. A 10 from me, but the Russian judge is just an 8... ;)
FGN59
  • France, Provence-Alpes-Côte d'Azur, Marseille
« Reply #17 on: March 07, 2020, 21:28:12 »
We have a French saying: ‘la critique est aisée, l’art est difficile’, which loosely translated means: ‘reviewing is easy, art not so much’. So let me put my reviewer persona on, and criticize >:( (it is not just the Russian judges who are difficult):
A Swede ;) has sent you a picture of a German :) tool, which appears to be bent, obviously on purpose, with precise measurements. And with your typical Yankee ingenuity, gung-ho attitude, and flair for cutting corners, you come up with a straight tool  ???.
So the old world heritage in my French blood ;D feels forced to cry out: don’t you think the Germans, with their obsessive preciseness and efficiency, put in that bend for a reason?  8)
François
1994 Toyota Land Cruiser SW HDJ80 4.2L diesel
sold:
1969 280SL US specs, 4-speed manual, beige-grey (726H), parchment leather
1962 Jaguar MK2 3.8L (4.2L XJ6 engine), black, tan leather interior
1968 Peugeot 204 roadster, white, black interior
1955 Massey Ferguson TEF20 diesel tractor 😁
mrfatboy
    • Mrfatboy
« Reply #18 on: March 07, 2020, 21:32:56 »
I was going to put the bend in it.  However,  when I tested it without the bend it worked perfectly 🤣
I guess Yankee ingenuity works👍👍👍😜
Signal Red
4 Speed
FGN59
« Reply #19 on: March 07, 2020, 21:37:31 »
I have to say, I am utterly convinced! But we still have cheeses, bratwurst and Swedish meatballs.
François
sold:
« Reply #20 on: March 07, 2020, 21:38:12 »
Not to mention the German tool is only good for one (right) side. The first photo shows the demonstration on the left side with the compartment open. The area in which it sits would not be accessible with the hatch closed.
 So one straight tool? Or two bent tools that mirror each other?
My Hazet exhaust donut tool works well for this.
FGN59
« Reply #21 on: March 07, 2020, 21:40:46 »
Let’s not underestimate the Germans... maybe the mystery will be revealed one day  ;D
François
sold:
« Reply #22 on: March 07, 2020, 22:46:43 »
a being Aussie blunt, a sledge hammer would have fixed it straight away. None of this fancy German high tech, American ingenuity or French delicate touches.
After all no one said they wanted to save the car, Rutger just said he wanted to get the hatch cover open.
FGN59
« Reply #23 on: March 07, 2020, 22:50:17 »
It’s been a long time since I last burst out laughing so loud. Thank you for that!  8)
François
sold:
mrfatboy
    • Mrfatboy
« Reply #24 on: March 07, 2020, 22:52:50 »
I think this thread is about a bunch of old tools 🤣🤣🤣🤣🤣🤣🤣🤣
Signal Red
4 Speed
