Author Topic: real axle code  (Read 1811 times)
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
real axle code
« on: March 09, 2020, 13:21:12 »
forgive me if I did't look hard enough in the Tech Manual, but could not find an answer.
On Data Card: Hinterachse (Rear Axle) what does the code 10790 signify- would this be the code for a specific rear axle ratio?  3.75 4.08?
JB; 1965 German market SL, Rot Met 571, Summary Code 213 Interior
WRe
Re: real axle code
« Reply #1 on: March 09, 2020, 15:38:43 »
the number in your data card is the serial number of your rear axle, no code. The axle ratio is not on your data card. You find the axle ratio beneath that serial number on your rear axle only, see https://www.sl113.org/forums/index.php?topic=25111.msg179488#msg179488.
...WRe
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
Re: real axle code
« Reply #2 on: March 09, 2020, 21:57:17 »
I found my axle code under the section on the data card that says   wenig gewunscht
my axle code (256) is listed right next to (740) folding top fabric, Black
I have no idea what "wenig gewunscht" means.
Looking at various cards on the internet and our site I notice that many cards don't have an axle type listed
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
WRe
Re: real axle code
« Reply #3 on: March 09, 2020, 22:35:53 »
"wenig gewünscht" means "rarely ordered" and option code "256" means "rear axle with limited slip differential (250 SL/280 SL)".
- https://www.sl113.org/wiki/DataCard/DataCards
- https://www.sl113.org/wiki/DataCard/OptionCodes
...WRe
Re: real axle code
« Reply #4 on: March 18, 2020, 21:17:27 »
Quote
On the 230 SL only the very first cars had the "3.75" rear axle ratio imprinted on the datacard next to its serial number.
On the car the rear axle ratio is imprinted on the most lower edge, the half-moon-like field on the lower rear edge of the differential if looked at from behind (from the tank side).
For your Euro-113042 it should read "SL  3/75" instead of "SL 4/08".
Benz280
  • USA, NJ, Jersey City
Re: real axle code
« Reply #5 on: March 22, 2020, 16:51:01 »
Hello All, with regards to the Limited Slip Differential Option Code 256 ) on a 113, as part of this was it a standard gearing or did them come with 3:92's .
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Aaron h
Re: real axle code
« Reply #6 on: March 22, 2020, 17:49:08 »
You could get a limited slip rear axle in any ratio if you asked for it when ordering the car.  Same on a subsequent installation.
