Author Topic: Going through my tool kit and found  (Read 5570 times)
JN
  • USA, NJ, egg harbor twp
« on: March 16, 2020, 15:30:43 »
In my tool kit I have 4 open end wrenches
8-10 Matador
11-13 Matador
14-17 Heyco with Star
17-19 Matador
Are these sizes correct and did I originally have all Matador?
I have looked for information but have not seen an answer
If anyone can help I would greatly appreciate it
JN
1967 250 SL Coupe
2014 GLK 250 BlueTec
1994 Ford F 150 4wd
kampala
  • USA, CA, Beach Cities
Re: Going through my tool kit and found
« Reply #1 on: March 16, 2020, 23:38:34 »
This is from our tech manual - lots of good info on tools.
https://www.sl113.org/wiki/Accessories/Toolkit
250sl - later - manual
280sl - 1971 - Auto - LSD
JN
« Reply #2 on: March 17, 2020, 02:51:42 »
yes I was there for an hour today
and still could not find an answer to my question
JN
1967 250 SL Coupe
1994 Ford F 150 4wd
mbzse
/Hans S
mbzse
« Reply #4 on: March 17, 2020, 08:34:13 »
The sizes of the wrenches:
19/17, 17/14, 13/11, and 10/8.
Before 1965, there was no size 13, so 14/11 instead.
In general, all four wrenches were from the same manufacturer.
Matador, Dowidat or Heyco. There can be variations, however
« Last Edit: March 17, 2020, 13:35:53 by mbzse »
/Hans S
JN
« Reply #5 on: March 17, 2020, 14:42:46 »
Thank you for the information and answering my question. Also thank you both for the previous past and link to the manual.
I enjoyed reading them. I am still having difficulty navigating through all this wonderful information.
Cheers
JN
1967 250 SL Coupe
1994 Ford F 150 4wd
« Reply #6 on: March 17, 2020, 17:04:34 »
At some point MB used 14 mm on their 8 mm nuts.  Probably why their wrench sets were also only 14 mm up to 1965. It could have been a cost saving directive to go to 13 mm instead.
mbzse
« Reply #7 on: March 17, 2020, 17:25:10 »
The change from 14mm to 13mm key width on the M8 nuts and bolt heads was an Industry wide change (DIN  Metric specification).
Allowed some size reduction of designs, and in a large machine brought with it some weight reduction as well.
See also https://www.sl113.org/forums/index.php?topic=29429.msg213005#msg213005
« Last Edit: March 18, 2020, 00:40:17 by mbzse »
/Hans S
