Author Topic: Part question  (Read 2551 times)
Part question
« on: March 18, 2020, 10:50:41 »
when I took my car apart I took pictures. here a picture of the switch that is linked to the automatic gear. Apparently the component with the arrow is close by.
Does anyone know what this is and where it belongs
Thanks, Peter
Re: Part question
« Reply #1 on: March 18, 2020, 12:04:22 »
Is it not the switch cutting off starter when gear selector is not in P or N? Goes on the fire wall.
« Last Edit: March 18, 2020, 12:13:47 by Pawel66 »
Re: Part question
« Reply #2 on: March 18, 2020, 15:20:20 »
The part by the blue arrow is the mounting bracket for the neutral safety switch. The switch is mounted to the bracket and then the bracket is bolted to the firewall.
Just went out and took a snap of the set up in my 280 SL.
Re: Part question
« Reply #3 on: March 18, 2020, 21:37:04 »
Thanks Jonny,
Location is now clear, but the function/construction not completely.
If I see it well on the picture the bracket is holding the blue “thing” behind the bracket? Or am I mistaken? Where is it going see right arrow? How does it work..
Thanks Peter
Re: Part question
« Reply #4 on: March 19, 2020, 03:16:46 »
Peter,
The blue arrow bracket if=s bolted to the car with the holes down and the two threaded studs up.  The switch is bolted to the bracket by using the two metal studs and two nuts.  Essentially the blue arrow bracket just raises the switch up a bit.
Re: Part question
« Reply #5 on: March 19, 2020, 07:29:01 »
I think the blue arrow bracket is just a "spacer washer". Firewall (the blue part) is not even, the switch is.
Re: Part question
« Reply #6 on: March 19, 2020, 15:38:25 »
On my picture the "blue thing" behind the bracket is the firewall. My car is DB 904 dark blue.
Re: Part question
« Reply #7 on: March 19, 2020, 19:06:39 »
Jonny,
Mounting is clear, thanks.
But how is it working as a “neutral safety switch”?
Re: Part question
« Reply #8 on: March 19, 2020, 19:29:45 »
Well, the lever on this switch is connected to the gear shift mechanism on the transmission.
It does two things:
1. It disconnects the power between the ignition key in "starter" position and starter switch solenoid (so that the starter will not turn) when gear selector is in 2, 3, 4 or R. It connects power from ignition key to starter solenoid when gear selector is in N or P - when it is safe to start the car.
2. It switches on back up lights when the gear selector is in R position.
Re: Part question
« Reply #9 on: March 19, 2020, 20:43:33 »
It does two things:
Thanks, all clear to me, but what does that thing with the blue arrow?
Re: Part question
« Reply #10 on: March 19, 2020, 22:10:30 »
It is just a spacer/support.
