Author Topic: Front train height  (Read 1706 times)
Léo Leclercq
Front train height
« on: March 19, 2020, 10:05:39 »
This is my first post, so Hello to everyone.
I'm working on a 230, especially on a height problem on the front.
The distance between the tires and the body is huge, about 15 cm.
First I've blamed the springs because i've been told that the front train comes from a another car, maybe a W108.
So I changed them for new ones order from sls, (mercedes part :113 321 02 04), with new rubber mounting according to the specification of the car , but still the distance didn't change.
Didn't find information about height in the manual.
Have you got any ideas
Thanks a lot
Léo
450sl
Re: Front train height
« Reply #1 on: March 19, 2020, 14:16:56 »
Hi Léo,  maybe your rearaxle  mount is collapsed ; check in the rear center of the boot if your plastic cap is in position or not.
mark
Aaron h
« Reply #2 on: March 20, 2020, 00:39:16 »
Leo, I hope this is of some use to you.  It's not easy to understand, but once understood it's always spot on.
« Reply #3 on: March 20, 2020, 10:15:11 »
Indeed, front ride height is a function of wishbone angle but few people have the tools to measure it.
There's been plenty of discussion on here about a more practical method for DIYers which involves measuring from wheel centre to wheel arch and comparison with others. A search should reveal the relevant threads.
mbzse
« Reply #4 on: March 20, 2020, 11:10:53 »
A basis for your SL is, the car should be level, and also same height right/left.
One can measure with a spirit level, on the threshold (with door open) and on the trunk valance (trunk/boot lid open)
« Last Edit: March 20, 2020, 11:18:20 by mbzse »
/Hans S
