Author Topic: What have you done to your pagoda during quarantine?  (Read 27520 times)
Re: What have you done to your pagoda during quarantine?
« Reply #50 on: May 02, 2020, 12:48:02 »
Clamps have been covered several times and I believe there is a section in the technical manual about them.
TJMart
  • USA, NC, Matthews
« Reply #51 on: May 02, 2020, 14:54:07 »
Where did you buy your Norma clamps??
Tony
Tony
1970 280SL, 4 Speed
mbzse
« Reply #52 on: May 02, 2020, 15:47:30 »
Quote from: TJMart
Perhaps not so convenient for you in the US;
but for you in Europe this is a vendor that supplies period type hose clamps for our Pagoda cars:
https://www.esys.co/shop/Spannbackenschellen-Schlauchbriden-Schlauchschellen-fuer-Oldtimer-DIN3017-2-Stahl-verzinkt-Breite-7-12-mm-Durchmesser-7-90-mm
« Last Edit: May 02, 2020, 18:57:46 by mbzse »
/Hans S
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #53 on: May 02, 2020, 15:49:21 »
Authentic Classics sells them here in the US.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #54 on: May 04, 2020, 04:34:52 »
Also Belmetric in the US.  Good people to deal with.
« Reply #55 on: May 08, 2020, 05:04:59 »
I have done the printing of the repro data cards for my car.  They look great, thanks to alpinaltd for his work.
« Reply #56 on: May 08, 2020, 08:42:55 »
I soldered a small radiator leak that developed some time ago. Took the radiator out from the bottom, having lifted the car on Quick Jack. I always had to go through hell setting the hood back after removal, no matter how carefully I marked the positions of the hinges... so removed radiator the "down" way.
On filling the coolant, I raised just front of the car with engine running - huge bubble of air came out. Radiator is tight.
I do not know what else to do on the car. I did everything.  ;)
« Reply #57 on: May 08, 2020, 09:40:30 »
You’re welcome to come play with my car.
mbzse
« Reply #58 on: May 08, 2020, 09:44:37 »
Quote from: Pawel66
.../...I always had to go through hell setting the hood back after removal, no matter how carefully I marked the positions of the hinges.../...
There is a simpler way for you...  Read here:
https://www.sl113.org/forums/index.php?topic=30649.msg222830#msg222830
/Hans S
« Reply #59 on: May 08, 2020, 10:24:52 »
I see. You bypass all adjustments this way. Clever...
I will do it this way next time, thank you for good advise, as usual from you.
mclewis
  • USA, NJ, Saddle River
« Reply #60 on: May 08, 2020, 20:34:35 »
Garry, what did you print the data cards on?  Did you use the background colors provided by alpinaltd or did you remove the background color and print the cards on colored paper stock?
Marc Lewis
1968 280SL 728H/728H, 248, 746
2020 C300
2021 E450 All Terrain
« Reply #61 on: May 08, 2020, 22:51:10 »
I used a laser colour printer and heavier card type paper and double sided the print such that the layout provided by Darren printed three cards per page, two on the pink colour, and I then cut them out to the edge of the colour.
mrfatboy
    • Mrfatboy
« Reply #62 on: May 08, 2020, 23:47:35 »
I removed the background color and printed the datacards on the correct cardstock color at FedEx.  I think it was 80# or 100#. It was there heaviest.
Some years have rounded corners.
Signal Red
4 Speed
« Reply #63 on: May 08, 2020, 23:57:19 »
I will have to put them somewhere or through a process to get them to age 50 years................😁
mrfatboy
    • Mrfatboy
« Reply #64 on: May 09, 2020, 00:22:00 »
Just bury them in the Outback for a week or so. It will give them a nice betina 🤣🤣🤣🤣.
Signal Red
4 Speed
« Reply #65 on: May 09, 2020, 01:02:30 »
My Owners Manual and Service Manual that has been kept up to date on services for 55 years look a bit worn in comparison. I think I need to just get slightly dirty and greasy hands and handle them for a couple of hours, that will match it up to the Service Manual.... ;D
Atazman
  • USA, Ca, Pleasanton
« Reply #66 on: May 25, 2020, 05:35:43 »
Took time to restore my dash wood.  I removed the radio speaker grill and hardtop wood but left the wood inside the windshield.  I thought I could do the restoration with it still in the car easier than taking the dash apart to get to the underside screws/nuts.
Anyway........ sanded with sand paper (I agree with the extreme caution in doing this); one coat of MinWax pre-stain conditioner; followed by 2 coats of Helmsman Spar Urethane Satin Clear coat.  i did not want to add stain because i wanted a much lighter color than the original wood.  The original "black" paint/varnish sanded away very nicely.
My picture of the final installation appears a little lighter than it really is.  The radio grill picture is more accurate.
Glad the wood has some new preservative on it.
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
« Reply #67 on: May 25, 2020, 17:03:52 »
Very nice!
john.mancini
  • USA, FL, Nokomis
« Reply #68 on: May 26, 2020, 14:15:52 »
Polished and waxed it today............from 6 feet away.
John
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
paults1
  • USA, FL, The Villages
« Reply #69 on: May 26, 2020, 15:21:13 »
Removed the air intake shield, checked the flap, removed the filter, cleaned it, cleaned the insides, not too dirty. replaced a few screws that were starting to rust, reassemble all components.
Martin Dwyer
  • United Kingdom, England, LEICESTER
« Reply #70 on: May 26, 2020, 23:15:45 »
Made a centre console.
mrfatboy
    • Mrfatboy
« Reply #71 on: May 28, 2020, 22:11:25 »
Went to FedEx Office today to print Alpinaltd's Kangol repro instructions. 👍  I printed on two different colored paper. Cut to correct dimensions.
I also was able to replace 2 incorrect hose clamps with the Norma clamps.
Signal Red
4 Speed
« Reply #72 on: May 31, 2020, 10:06:45 »
Today, I saw my car, and got it out of the garage, for the first time since the first week of March
« Reply #73 on: June 05, 2020, 00:46:04 »
Broke the 230SL out of quarantine yesterday morning for a quick run to the grocery store and Lowes.  Parked it way out in never never land.  When I finally returned to the car with my light bulbs and four sacks of provisions there was an impromptu car show going on in that corner of the parking lot!  I'm so sad that I didn't have so much as a cel phone with me - here's what were lined up with the Pagoda:
289 Cobra
mid-70's 124 Spyder
2CV Citröen
58/59 T-Bird
M-B W116 Sedan
I hung around to see if I could meet any of the drivers, but only got to meet the kid who owned the Fiat and his girlfriend before the ice cream started to melt.
su8pack1
  • USA, PA, Barto
« Reply #74 on: June 09, 2020, 02:17:29 »
I replaced a fuel hose from the tank to the pump that was leaking, and a heater hose from the block that was also leaking.
1984 300CD
1987 190E 2.6
1988 190D 2.5
