Author Topic: Euro head light glass clips  (Read 4269 times)
« on: March 26, 2020, 21:07:41 »
Anyone have any pointers on how to install those little C shaped clips that hold the head light glass to the frame? Either you put the clip on the glass first or on the frame first but either way can lead to unhappy results.
Any help would be welcomed.
Re: Euro head light glass clips
« Reply #1 on: March 26, 2020, 22:10:08 »
I've typically put the clips onto the body first, then use a sharp hook to 'pull' them gently over the glass - it takes some force as these clips are surprisingly strong.
mbzse
« Reply #2 on: March 26, 2020, 23:49:46 »
Yes, body first.
I sometimes use  a small L-shaped Allen key.
Or, a loop of copper wire (when in position, cut wire and pull out)
/Hans S
GM
  • USA, CO, Boulder
« Reply #3 on: March 27, 2020, 01:36:36 »
Funny - I do the exact opposite. I hook the glass first and then hook the rear over the bump on the metal. I tried the above method the first time and chipped the glass.
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
cfm65@me.com
  • Cape Town, South Africa
« Reply #4 on: March 27, 2020, 06:51:39 »
I am with Gary on this one. Forcing the clip over the metal is preferred to forcing it over the glass.
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #5 on: March 27, 2020, 08:42:53 »
I am also one that has tried both ways and chipped the glass when trying to go from Body to glass.so went with fitting over glass then onto the metal.
« Reply #6 on: March 27, 2020, 22:10:03 »
Me too.
Made the same experience...  :P :-X
After some chipped lenses, only the second way like Garry and Gary posted works properly.
The other way round is too dangerous...
(usedeuroheadlightassembliescollector)
« Reply #7 on: March 27, 2020, 22:55:54 »
I agree, it does take exceptional skill  8)
« Reply #8 on: March 28, 2020, 04:16:08 »
Thanks guys. I kind of thought so but you can never be completely sure until you ask.
hkollan
  • Spain, Castilla-La Mancha
« Reply #9 on: March 28, 2020, 16:49:11 »
Having restored about a dozen of these headlights over the years, my conclusion is,
glass first.
Hans K
Hans K, Cuenca, Spain
« Reply #10 on: March 28, 2020, 18:33:22 »
I guess that the intuitive reason for me go put the clips on the body first is that the act to pull the clip over the second ridge (in my case, the glass) puts the most stress of the whole procedure on the first ridge (my case: the body). Once it's over the second ridge, the tension is lowered. So I rather put that extra stress on the body, not the glass. But happy to give the other method a try, next time.
