Author Topic: Old faded,windscreen post seals,repairs.  (Read 3519 times)
wayne R
« on: March 29, 2020, 06:57:14 »
Thought i would show a few tips to repair those old faded front windscreen post seals.
Take a look at my original drill cloth that has turned white and  mostly worn and gone.
As long as the actual rubber is still sound and in good condition,all that is required is
Adhesive backed Bow drill cloth,comes in 5 inches x 5 ft and  under $30, and very easy to apply.
Prep the old  seal first with prepsol wax ,greese, remover,then cut the bow drill cloth approx 1/2
bigger than required,this material is very thin like tissue paper,so start at front outside  edge from top to bottom
then gradully  move around to  inside  chanel,then to the inside,rubbing with a small blunt edge srewdriver
up and down, then trim with very sharp  blade knife or swissors.--finished ,you wont believe the differents,
it lasts for years and does not  move it is also used for around convertble seals on all GM products,im not ,
going to do my top seals, as i have only ever had my top up about 3 times.Cloth is available at ---www.oldbuickparts.com
New Jeysey, Go to top left-up to 1960, then go to Group13 convertble tops, then go convertible tops. parts.--- few photos ,regards.
« Last Edit: March 29, 2020, 13:15:40 by wayne R »
wayne R
Re: Old faded,windscreen post seals,repairs.
« Reply #1 on: March 29, 2020, 07:03:11 »
Few more photos---Hope it helps anybody thank you.
« Reply #2 on: March 29, 2020, 11:21:46 »
I think this is a very good tip, thank you!
I think this may also apply to the B-pillar seals.
What is the Bow drill tape?
I remember this was my biggest issue - to find a proper material. I remember I found a grip tape for bicycles and/or for tennis racket. What is yours exactly?
wayne R
« Reply #3 on: March 29, 2020, 13:10:10 »
Sorry  Pawel i should have called Cloth, it is actually very light thin  weaved canvas,yes you are correct,
used for all B pillars, the bow drill cloth is for the main  members on all,Buick, Cadillac, Oldsmobile  convertible tops, see my original page
follow my instructions  at  old buick parts,and take alook,it shows seals ,cloth, sizes,etc regards.
« Last Edit: March 30, 2020, 10:55:39 by Peter van Es »
wayne R
« Reply #4 on: March 29, 2020, 13:39:21 »
Before and After,----photos
« Reply #5 on: March 29, 2020, 13:39:59 »
Thank you!
I certainly looked through your first post, I just had no idea what "Bow drill cloth" might be. My poor English, sorry.
Now I googled it and I know. I did not know it existed: bowdrill cloth tape. I wonder if there is an equivalent in Europe...
https://www.steelerubber.com/bowdrill-cloth-tape-70-1172-65
Dave H
  • United Kingdom, England, Durham
    • Dave H
« Reply #6 on: April 07, 2020, 20:24:19 »
Thanks for the tip Wayne, just ordered some from    garyk@oldbuickparts.com.
Gary was very helpfull, I  had been looking for a product like this for ages but did not know you could get it, bow drill cloth , who knew , thanks again Wayne
Mercedes 250SL    1967
Mercedes 250SLK  2014
Alfa Romeo 166 3.2 Ti
Fiat 500
mnahon
  • Canada, QC, Montreal
« Reply #7 on: April 11, 2020, 17:59:09 »
Do others with later model 280SLs have this fabric covering on these seals? The seals on my car seem to be plain rubber.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
« Reply #8 on: April 11, 2020, 19:38:57 »
the A-post seals on all models should be cloth covered to allow smooth up and down movement of the window glass. Without the cloth the rubber can also bake onto the glass on a very hot day. If you buy the seal new from MB it will be cloth covered, if you buy aftermarket, e.g. URO, then it is just bare rubber.
In that case you might treat the rubber with a solvent-free lubricant (no silicone!). PFPE oil such as Krytox GPL-105 or 106 are a good choice; these oils also come as grease when mixed with PTFE particles. You can also get them as a roll-on stick applicator which I like.
https://www.ebay.com/itm/Krytox-GPL-106-PFPE-Oil-14g-Auto-Roof-Door-Weatherstripping-Rubber-Lubricant-105/251863267449
https://www.ebay.com/itm/Gummi-Pflege-Stift-Rubber-Care-Stick-3-4-fl-oz-3-4-fl-oz/222277543050?
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #9 on: April 11, 2020, 20:47:39 »
I think the newer URO A pillar seals have a fuzzy velour type coating.  Better than plain rubber but still not like OEM fabric.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Dave H
    • Dave H
« Reply #10 on: April 12, 2020, 10:14:42 »
Was it just  A post seals which were originally cloth covered ?
What about the B posts on the hard and soft top?
Mercedes 250SL    1967
Fiat 500
« Reply #11 on: April 12, 2020, 10:18:42 »
I remember a discussion on this Forum where it was said that in the past both A and B pillars seals were fabric coated. Now B seals are plain rubber. But A seals, when I bought them from Mercedes 6 years ago, were still fabric coated.
« Reply #12 on: April 12, 2020, 11:38:16 »
Wayne,
Just tried to order some of the tape but they wanted only $12usd for it but $30usd to send from US.
Did you get it here or USa?
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Dave H
    • Dave H
« Reply #13 on: April 12, 2020, 17:12:42 »
After much searching I ordered mine a couple of days ago from garyk@oldbuickparts.com.
2.5 ‘ wide was $15, 5’ wide was $29, I opted for the 5 inch wide.
Same $30 dollar postage to the UK though.
Mercedes 250SL    1967
Fiat 500
« Reply #14 on: April 12, 2020, 21:36:51 »
Thanks Dave.  It was the $30 usd that made me balk at purchasing. I will ask if they will send usps rather than usp.It should be half that cost.
wayne R
« Reply #15 on: April 12, 2020, 23:27:43 »
Sorry just found it,    busy--, thanks for your help Dave,and  Garry i still had that piece
left over from my days with Buicks and Cadillacs, it is actually about  25 years old,
had it all that time from when in USA.
Yes you are correct the shipping price to Ausy is crazy,i just in last couple of weeks ago,
i purchased a  small  SK Wayne  10mm antique wrench,to complete my set, $10, but the shipping was  $17,
through ebays now global  shipping system.   regards .
« Last Edit: April 13, 2020, 00:08:10 by wayne R »
Benz280
  • USA, NJ, Jersey City
« Reply #16 on: June 08, 2020, 14:04:06 »
So the question may be, do you replace seal or go with the tape ?
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
GM
  • USA, CA, San Pedro
« Reply #17 on: June 08, 2020, 16:39:57 »
Or, if it's just the fading you're concerned about, shoe polish works great!
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
