Author Topic: Engine accelerates when I step on the brake??  (Read 2748 times)
south280
« on: April 02, 2020, 12:42:23 »
Hi, this just started out of nowhere, when I am in neutral (standard shift car) and press on the brake pedal the engine slightly accelerates...   any help would be appreciated. 1968 280sl   Thanks, David
WRe
Re: Engine accelerates when I step on the brake??
« Reply #1 on: April 02, 2020, 13:04:06 »
I would assume leak air, check vacuum line and check valve from brake booster to intake manifold.
...WRe
« Reply #2 on: April 02, 2020, 18:47:36 »
When you press the brake pedal, brake booster is using vacuum from intake manifold through a hose with a check valve that allows flow in one direction. If booster is air tight, it is "sucked" by vacuum, revs may go slightly up as manifold gets a bit of air from the booster and then back down almost immediately. But if booster is leaking air, it continues giving more air to the manifold - revs just increase just a bit or more, depending on the size of the leak.
south280
« Reply #3 on: April 02, 2020, 20:33:44 »
ok thanks for the info....here is an update...     after the car is running then shut off, I press my foot on the brake pedal and I can hear what sounds like a gush of air from inside the booster itself.  If i press the brake pedal again no sound?     do I need a new booster and if so can I change it myself or is this a big job e.g bleeding breaks etc?
twistedtree
  • USA, VT
« Reply #4 on: April 02, 2020, 23:12:00 »
New booster, or have it rebuilt.  They aren't hard to remove and replace.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
