Author Topic: fuel injector copper seals  (Read 2776 times)
jim 56
  • USA, NY, Bellerose
« on: April 04, 2020, 22:57:40 »
Hello all I just took out my fuel injectors out to backflush.there was one seal missing.Does anybody know the part number they are for mechanical fuel injection R2 injectors.I will buy all six.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: fuel injector copper seals
« Reply #1 on: April 04, 2020, 23:06:40 »
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Aaron h
« Reply #2 on: April 04, 2020, 23:11:03 »
MrFatboy, that link is for an actual injector.  I think he was looking for the seal ring for between the injector and the cylinder head.  But, the listing does make mention of the seal ring over to the right in small print.  Part number N007603-014100.
The last time I ordered these from Mercedes I received aluminum seal rings.  Absolutely useless.  The aluminum is too soft, it splits when you tighten the injector, and the injectors end up vibrating loose.   Always use copper if you can find it.
mrfatboy
    • Mrfatboy
« Reply #3 on: April 04, 2020, 23:12:13 »
The link is fixed.
Signal Red
4 Speed
Aaron h
« Reply #4 on: April 05, 2020, 00:21:53 »
Yay for MrFatboy!  :)
« Reply #5 on: April 05, 2020, 00:43:15 »
14 x 18 x 1 copper seals.  Available at pretty much any auto parts store.  OR on Amazon as a set.
« Reply #6 on: April 05, 2020, 01:40:38 »
I agree and if you work on these cars at all, having a seal ring kit is the way to go. Frustrating when all you need is a cheap seal ring to finish a repair and you don’t have it.
« Reply #7 on: April 05, 2020, 02:21:32 »
I have an entire drawer in my workbench dedicated to "Kits".  Screws, nots, washers, grease fittings, O-rings, vacuum fittings etc.
PeterW113
« Reply #8 on: April 19, 2020, 12:22:01 »
Thanks to this post I was able to order the correct size seals and I am now embarking on replacing my injectors with new ones which have sat on the workbench since Christmas.
Cheers,
1968 MB 280SL, RHD Auto
1968 Lotus Elan +2
1965 Fiat 500
2004 BMW 1200 GS
« Reply #9 on: April 19, 2020, 14:03:31 »
There is this gentleman on youtube, Car Wizard. He says he uses only the green orings for all purposes, as they are made of better material. What is your, professionals, view on this?
WRe
« Reply #10 on: April 19, 2020, 14:33:45 »
here you find everything you want to know about o-rings.
...WRe
« Reply #11 on: April 19, 2020, 15:36:21 »
I cannot open the O-ring guide on my IPAD, but I can tell you with 100% certainty, there is not ONE material that is compatible with all of the fluids (including air and vacuum) in an automobile. Using just one material is foolish. Not sure what the green is and there are not necessarily standards for color. You really can’t go by color alone.There are super compounds that may get close, but why not use the best suited material for the longest life?
Using a compatibility chart is easy and works every time. Probably would be a good idea to post one of these charts on this site in the Tech manual as this topic frequently comes up. I have been around rubber and urethane for 40 years now, and there are some industry secrets, but using a compatibility chart is a no-brainer.
« Reply #12 on: April 19, 2020, 16:09:39 »
Thank you and thank you for the handbook.
Green orings were those used in the air conditioning systems that is how he was describing it. You can but sets of various sizes of these green orings, just like sets of oil resistant orings (usually black).
« Reply #14 on: April 21, 2020, 14:16:28 »
Some of my Kits.
