Author Topic: Correct Tire Jack and Wheel Chock  (Read 15190 times)
Andres G
  • USA, FL, Miami
    • Toyota Adventure Team
« on: April 13, 2020, 15:51:18 »
Hello Folks,  I hope everyone is doing great and staying healthy.
Some background to my question:  A few years ago, at the time of moving into my current home, I had my pagoda at the body shop for a color-sand and buff, and had kept everything from the trunk at home.  Well, as you probably already guessed, all of it magically disappeared and I've since been trying to purchase back all of the missing parts.
Wheel and tire were easy, as was the cover for it.  My tool kit re-surfaced so I was saved with that, but I am now trying to find the correct Tire Jack and wheel chock.
Ask: Can anyone identify what is the correct model Bilstein tire jack?  I was under the impression it should be AB1922 - Can anyone confirm?  The car is an Euro-250 SL (Italian Market).
Thanks in advance,
Andres G
wjsvb ✝︎
  • USA, VA, Virginia Beach
Re: Correct Tire Jack and Wheel Chock
« Reply #1 on: April 13, 2020, 21:01:07 »
I recently dug the jack and wheel chock out of my early US 250SL.  The jack is the earlier type with a separate ratchet handle.  If needed, I can get a pic  next time I visit the car.
jon
67 250SL early
81 280SL Euro 4spd
Andres G
  • USA, FL, Miami
« Reply #2 on: April 13, 2020, 21:36:19 »
Hi Jon, thanks for your offer.  My 250SL is a later model, and came with the single piece one.
I did find an OEM NOS wheel chock,  and almost passed out when I saw it was $425 on e-Bay.  Called the dealer and found it for $1550 + Tax!!!   I will be drinking some Malbec to aid with the healing process.  Snif...
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #3 on: April 14, 2020, 01:17:23 »
I have never seen a late 250 SL with the one piece jack. Always been the two piece as my early 280sl.  Is this a Euro-itailian configuration? I thought the one piece jack was a later 280sl change.
I'm curious to know what is correct.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
kampala
  • USA, CA, Beach Cities
« Reply #4 on: April 14, 2020, 02:02:58 »
My late 250 also came with the early screw type jack with separate ratchet type handle. Not the one piece.
250sl - later - manual
280sl - 1971 - Auto - LSD
mbzse
« Reply #5 on: April 14, 2020, 11:00:09 »
Quote from: mrfatboy
I have never seen a late 250 SL with the one piece jack. Always been the two piece as my early 280sl.../...the one piece jack was a later 280sl change.../...
This is correct, yes
/Hans S
Andres G
  • USA, FL, Miami
« Reply #6 on: April 17, 2020, 14:42:30 »
Hi Jon, I guess from the answer above that I could use a picture of it if you can share.  I assume what was in my car was not the original...
mrfatboy
    • Mrfatboy
« Reply #7 on: April 17, 2020, 14:51:16 »
Here is a picture of a jack from an early 250sl (same as my early 280sl).  Notice how the jack snaps into the metal spring clamps.
The later crank style jack will not correctly fit in earlier spring clamps.
Signal Red
4 Speed
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
« Reply #8 on: April 17, 2020, 17:36:33 »
Sorry to jump on this thread with a question.
My 230sl jack came to me as shown with the ratchet in its own floor holder.  Most pix show the ratchet  inside the jack screw as the picture in the thread before mine.  If that is correct, what is the unused floor clip for? Or, were there multiple options for securing?
JB
« Last Edit: April 17, 2020, 22:59:43 by SADIE »
« Reply #9 on: April 18, 2020, 16:01:32 »
The parts books for the early 230 SL show the jack handle as fitting inside the jack, as mrfatboy's photo shows. Perhaps the other clip could be used for the wheel centering pin?
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #10 on: April 18, 2020, 16:30:13 »
The wheel centering pin was in the extra clip in mine...
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
SEB
  • Germany, Berlin, Berlin
« Reply #11 on: June 28, 2020, 12:06:58 »
Gentlemen's
And can I ask which model is this tire jack? I have an early 250SL and was thinking all the time I have the correct one.
Thank you for your  help!
« Last Edit: June 28, 2020, 12:13:42 by SEB »
Sebastian
1967 250 SL, 4 Speed, Euro spec, Tunis beige (462H),
mbzse
« Reply #12 on: June 28, 2020, 12:18:46 »
.../... can I ask which model is this tire jack? I have an early 250SL .../...
Correct for the 250 SL and early 280 SL is the external spiral type jack, with a separate handle (ratchet).
/Hans S
SEB
« Reply #13 on: June 28, 2020, 12:29:41 »
Many thanks Hans! Do you have maybe an idea from what car is my tire jack?
Sebastian
mbzse
« Reply #14 on: June 28, 2020, 12:31:04 »
Late 280 SL Pagoda, as well as all other models like W108, W111 cp/cab and W114/115 Compact
/Hans S
SEB
« Reply #15 on: June 28, 2020, 13:04:58 »
Thank you Hans!
Do you know if this old style tire jack was in all old Mercedes used before W108/ W114/115 or only in a Pagoda?
Sebastian
mbzse
« Reply #16 on: June 28, 2020, 13:22:26 »
The open spiral type jack was used by W121 Pontons and W110/111 Finbacks as well as other Mercedes types
/Hans S
SEB
« Reply #17 on: June 28, 2020, 13:49:41 »
Many thanks Hans!
Last question- which one is more convenient? I know only the new one how it works. Is it equal in using or is it one step backwards?
Sebastian
Merc_Girl
  • United Kingdom, England, Godalming
« Reply #18 on: August 01, 2021, 22:12:41 »
Does anyone happen to know if the early 230SL, with vertically mounted spare wheel, had a wheel chock?
If so, where about where this was stored? I see that the pagodas that have the ‘horizontal’ spare, have these either mounted on the ‘stand’, although have seen an image of one screwed down in the wheel well, although not sure hoe accurate that is!
Many thanks
230SL
« Reply #19 on: August 01, 2021, 23:14:36 »
For 113042 I have from parts list:
Chock, PN A 110 583 01 75, Plant information: As of ident. no.: 042 007205 EXCEPT FOR: 007216, 007232 ALSO INSTALLED ON 006069
I think this was the time of the spare wheel location re-arrangement, floor and fuel pump cover took place (but not the tank change! - this took place with 250SL). Together with the spare wheel re-arrangement chock appeared.
That is what parts lists plus some other info are saying.
Merc_Girl
« Reply #20 on: August 02, 2021, 17:34:45 »
Ah ha
So, as I have the spare vertically mounted, I surmise from your research that my 230SL did not have a chock. I’ve looked at the owners handbook and given there is no mention of it there which I presume those who have chocks would have?
Thanks for confirming Pawell66 😁
230SL
« Reply #21 on: August 02, 2021, 19:56:39 »
Just another theory as in the case of the third nipple...
MikeSimon
  • USA, OH, North Royalton
« Reply #22 on: August 02, 2021, 20:20:51 »
My parts list shows 110 583 0175, wheel chock for ALL models. The jack is listed different for 230SL, old version.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Merc_Girl
« Reply #23 on: August 02, 2021, 21:51:49 »
Third nipple???
230SL
« Reply #24 on: August 02, 2021, 21:51:58 »
Well, you can never be sure...
There is a clear note "as of..." .
I changed the sentence a bit: it does fit all models, if that is the criteria for classification in that part list, but the EPC is quite accurate as for what went where and when, so it fits all 230SL, it just was fitted as of certain chassis.
« Last Edit: August 02, 2021, 22:20:05 by Pawel66 »
