Author Topic: Banjo Fittings  (Read 1825 times)
Harry
  • USA, TN, Knoxville
Banjo Fittings
« on: April 14, 2020, 00:43:18 »
I'm curious.  It appears on my 230SL that a fitting with a banjo bolt has a soft washer under the bolt head but nothing between the fitting itself and the mating surface?  Is this correct?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Banjo Fittings
« Reply #1 on: April 14, 2020, 05:24:22 »
I believe they have metal seals on both sides of the banjo fitting.
Harry
Re: Banjo Fittings
« Reply #3 on: April 14, 2020, 11:44:44 »
I also would have expected a soft metallic gasket/seal on both sides but it doesn't appear that is the case when I look at some of the original fittings that I don't think have ever been broken on my car.  However it sounds as though when others on the forum have broken and reassembled these types of fittings, they have placed such a seal on both sides?  The coolant bypass tube on the head is a good example.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Aaron h
Re: Banjo Fittings
« Reply #4 on: April 14, 2020, 21:57:50 »
The coolant bypass hose always had two crush washers on each side of the fitting.  If you'll look in a parts book or catalog all of the fuel line fittings like this require two crush washers.  They all show (2) quantity for each fitting.
UJJ
  • USA, CA, Grass Valley
Re: Banjo Fittings
« Reply #5 on: April 15, 2020, 13:54:03 »
I bought everything related to Banjo Fittings here:
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
Harry
Re: Banjo Fittings
« Reply #6 on: April 16, 2020, 16:55:27 »
Wow - that's a good resource to make note of.  Thanks.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
