Author Topic: NAPA Echlin EAS-70 Electronic Amplifying System on my 250SE  (Read 3281 times)
col320ce
I've just seen this box which I thought was an alarm but it's an ignition system.  Has anyone had any experience with these? I'm wondering if this has got something to do with the cold start valve being disconnected??  Not sure whether I should be disconnecting it or not ... or re connecting the cold start valve??
Any thoughts?...
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
lpeterssen
  • USA, FL, Miami
Re: NAPA Echlin EAS-70 Electronic Amplifying System on my 250SE
« Reply #1 on: April 21, 2020, 10:40:46 »
Dear Col
If it is an ignition system it has nothing to do with your cold start valve.  This should be related only with the ignition coil.  Verify to which sistema it is connected and let me know.  In all the Mercedes I own I have electronic ignition systems installed, so I can guide you somehow.
Best regards
L.peterssen
col320ce
« Reply #2 on: April 21, 2020, 12:27:51 »
Thank you!!
I'll trace the wiring of it tomorrow and let you know how it is set up.
Col
1964 230SL
1965 250SE coupe
col320ce
« Reply #3 on: April 22, 2020, 08:36:30 »
So this is what I have:
Red:  To the distributor/condenser.  Condenser still connected
White and Green: To the Ignition Coil
Black: to earth and directly to the negative battery terminal
Suggestions on leaving it verses removing it or something in between?
Thanks again
Col
1964 230SL
1965 250SE coupe
lpeterssen
  • USA, FL, Miami
« Reply #4 on: April 22, 2020, 11:19:19 »
Dear col320ce
I made a search on the web to find the manual for your ECHLIN transistorized ignition module which led me to a post on sl113.org forum dated back in 2010.
After reading most of it and referring to an important part of the electrical manual posted on this same site related to transistorized ignition systems, my conclusion is LEAVE THE MODULE AS IS. You need it to reduce the wear on your ignition points.
Just check that you have all the components as stated on the electrical diagram published there.  Specially the part that ignition resistance is composed of two separated resistors. One for o.4 ohms and a later one with 0.6 ohm.  Those are critical to have the exact current needed to make your systems work flawlessly.
See this link:
https://www.sl113.org/wiki/Electrical/TransistorIgnition
Best regards
L.peterssen
