Author Topic: Complete Engine rebuild  (Read 2667 times)
john.mancini
  • USA, FL, Nokomis
« on: April 23, 2020, 01:11:56 »
Looking at a pretty nice 230SL. Very nice body, from a dry climate. No previous rust or accident damage. My impression is that it needs an complete engine rebuild though. Something I know very little about. I do know that blue smoke that doesn't go away once the engine is warmed up is not a good sign. Has anyone out there had a recent rebuild? What am I looking at cost wise? Roughly?
John
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
Vander
  • USA, OH, Columbus
Re: Complete Engine rebuild
« Reply #1 on: April 23, 2020, 01:55:58 »
230SL engine parts cost more than 280SL. $10-15k.
john.mancini
  • USA, FL, Nokomis
« Reply #2 on: April 23, 2020, 02:25:14 »
Thanks Vander. Good to know.
John
98 911 cab
56 Ford F100
23 Z4M40i
« Reply #3 on: April 23, 2020, 15:43:09 »
Depending on the total mileage, a complete cylinder head rebuild will cure problems like this 90 % of the time.
« Reply #4 on: April 23, 2020, 17:22:24 »
Yes, but any buyer should allow for a total rebuild in the price negotiated..........
« Reply #5 on: April 23, 2020, 21:59:53 »
And for my 6,000th post. ( TA DA )   ;D
Joe, that's kind of like having a vasectomy done on just one side. It only fixes half of the cause and almost none of the problem .  :)
« Reply #6 on: April 23, 2020, 23:03:52 »
Mercedes-Benz publishes massive amounts of technical data and "permissible wear limits" so you can make an informed judgement on what is worn out and what is still usable. it is always easiest to replace everything with new if your pockets are deep enough.
MikeSimon
  • USA, OH, North Royalton
« Reply #7 on: April 23, 2020, 23:29:45 »
The only thing in the lower end that could causes "blue smoke" are worn rings. Relatively easy diagnosed with a thorough compression/leak-down test. Quite a few other things can cause it in the head, so I would agree with Joe on that.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #8 on: April 24, 2020, 01:11:32 »
Depending on the mileage and history, when the head is off, often times I will remove the sub-pan and slide a piston out the top, to spot check the condition of the rings and piston ring grooves.
Esmo
  • United Kingdom, Wales, Conwy
  • SL 230 1967
« Reply #9 on: April 25, 2020, 11:13:44 »
I’m currently half way through what started as an engine bay tidy up for my SL230 in the U.K. .The cost will very much depend on what outcome you will the happy with. Shipwrights syndrome more commonly known as Shipwrights disease is the major risk. If you employ a specialist £20,000 was quoted to me.
      In short ,Bonnet /hood removed ,engine out ,strip down the easy bit. Send all metal (except injectors and fuel pipes ) for passivation, powder coating ,painting or coating including bolts screws and washers .
     Buy new injectors ,fuel lines. Buy new, all rubber, gaskets ,seals and filters . With the engine out arrange an engine bay respray. Send radiator for re core and renew hoses. The engines out so the ideal time to replace steering rods king pins and dampers .Arrange for the head to be re built . Send engine for measurements discover problems and decide to buy a new set of pistons . You may be able to come in at about £12,000 if you do some work yourself. Good luck, only other thing is allow lots of time .
RobSirg
« Reply #10 on: April 25, 2020, 14:13:48 »
……. that's kind of like having a vasectomy done on just one side.
Surely you'd have to be half-nuts to get one side done?  ;D
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #11 on: April 25, 2020, 17:30:16 »
You guys are too funny!  :D ;D ;) ;)
FresnoBob
  • USA, CA, Fresno
« Reply #12 on: April 27, 2020, 22:11:08 »
I would speak with Mike at Metric Motors in Los Angeles.  He is truly professional and his work is exceptional.  He only rebuilds these types of motors.  I recently installed a fully rebuilt 250 motor from Metric and I'm most impressed.  Looks beautiful too.
Bob Comstock
1966 230 SL Euro Auto
2017 AMG C43 Cabriolet
« Reply #13 on: April 28, 2020, 04:36:59 »
I'm not a slow mechanic and I'm not a fast mechanic; I guess that makes me a half fast mechanic.
