Author Topic: Center console box mounting  (Read 2258 times)
prefervintage
  • USA, CT, Cheshire
  • '69 280SL,'70 280SE,'82 300D,'85 Rolls,'66 Mustang
« on: April 25, 2020, 04:37:00 »
Hi all...my SL evidently had the carpets out years ago before I bought the car...the center console box between the seats has never stayed in place properly, wobbling left & right. It appears this was mounted using only two screws into the driveshaft tunnel. This makes no sense to me to make for a solid secure mount...was there originally some kind of contoured (to the tunnel) support that in turn was screwed to the box? Any sugesstions most appreciated...thanks...Joe
Re: Center console box mounting
« Reply #1 on: April 25, 2020, 06:05:05 »
Mine too has two (one poorly fitting) screws in line with the tunnel holding it not very securely in place. I’ve always assumed it’s normal but now you mention it, it does seem out of keeping with everything else
« Reply #2 on: April 25, 2020, 08:09:17 »
There are, or should be, to mounting brackets.
/Peter
prefervintage
  • USA, CT, Cheshire
« Reply #3 on: April 25, 2020, 11:46:52 »
Two screws and wobbling does seem out of character for Daimler-Benz...Well depending on the posts here, if there are no special supports underneath, I'll have to design one we can all use. I'm thinking of a thin hard Delrin strip with a recess that contours to the driveshaft tunnel, held in place by at least four screws, but flat on top where the console box can bolt...thoughts?
mbzse
« Reply #4 on: April 25, 2020, 18:23:43 »
Quote from: prefervintage
.../...the center console box between the seats has never stayed in place properly, wobbling left & right. It appears this was mounted using only two screws into the driveshaft tunnel.../...
Two screws, one into each little console (bracket) on the driveshaft tunnel is correct, yes. Some info and pictures in this thread:
https://www.sl113.org/forums/index.php?topic=30525.msg221327#msg221327
/Hans S
prefervintage
  • USA, CT, Cheshire
« Reply #5 on: April 26, 2020, 00:24:23 »
Thanks Hans...I didn't know there was a bracket under the carpet...I'm planning to replace the carpet after the car gets striped and painted thus summer...question...what have people done to add insulation under the carpet? Is there some kind of precut material? I would think this would be a good sound deadening move...
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #6 on: April 26, 2020, 00:37:47 »
Search "Dynamat" here on the forum.  Lots of info.
Here is just one example.
https://www.sl113.org/forums/index.php?topic=22687.msg162540#msg162540
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #7 on: April 26, 2020, 00:38:43 »
There has been a lot of discussion on sound deadening recently.  The search button on the Home line is your friend
Here is one. https://www.sl113.org/forums/index.php?topic=30496.msg221365#msg221365
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
« Reply #8 on: April 26, 2020, 04:16:18 »
The carpet should not be installed over the two brackets on the tunnel but tucked underneath. Best is to make a cut in the middle of the bracket and then tuck the ends under the bracket. That will prevent the wobble.
Interestingly on my 1964 230SL there was a rectangular seamed cut out for the rear bracket; on the front the carpet was glued to the tunnel.
When I installed a new carpet I did not recreate the square cut-out but just tucked the ends.
I am not sure when this change was made but on my 1966 230SL the carpet was cut und tucked under the two brackets.
mbzse
« Reply #9 on: April 26, 2020, 19:55:49 »
Quote from: 66andBlue
The carpet should not be installed over the two brackets on the tunnel but tucked underneath.../...
Well, the 280SL /8 in the photo is original. Manufatured January 1968. Carpet is certainly glued to the transmission tunnel, from factory.
And installed over the brackets...
/Hans S
