Author Topic: timing questiond  (Read 6176 times)
Re: timing questiond
« Reply #25 on: June 28, 2020, 19:56:11 »
You then re-adjust the idle again to specs.
Berggreen
  • Denmark, Zealand, Gentofte
« Reply #26 on: June 28, 2020, 20:04:28 »
Hi Christian,
Thanks for advice, interesting!
Adding more shims under the barometric compensator will also influence the CO level of the idle speed adjustment which should be between 3,5/4,5%.  Do you have experience what the level than should be?
Thanks, Peter
Hi Peter
Yes and CO% 3.5-4.5 if possible, and it does not go out at the end of the warm runnnng program. If it does, I give it a bit richer mixture at idle with the idle mixture screw.
I think the most important is that the mixture is correct in the mid and high rpm range. And this can only be checked by watching the spark plug color, unless you have access to a dyno-field, where you can measure the CO under load. :)
Also watch out for pinging, indicating a too high advance. But it should’nt be, if you have 8 degrees BDTC at idle (800 RPM).
Cheers,
Christian
02/1971 MB 280SL (aut.) - olive green 291H
11/1970 MB 280SL (man.) - silver 180G
12/1977 MB 350SE (aut.) - deep green 825H
03/1969 Volvo 1800S (man.) - dark green 94
« Reply #27 on: June 28, 2020, 20:33:40 »
Thanks Gents,
I'm going to take a close look at the spark plugs and fuel mixture as it is not the intention to damage the engine.
